pondking Posted November 2, 2013 Report Share Posted November 2, 2013 cruisin in the freeway suddenly stopped the pedal was stuck but they popped back up now its stiff and it starts whistling and its pretty difficult to stop the pressure increased dramatically im not sure if it effected the idle before but it seems so now i apply the brake and it changes so, do brakes cause the idle to change when parked? i know the rotors are messed up could that be it? Quote Link to comment
datzenmike Posted November 2, 2013 Report Share Posted November 2, 2013 Brake booster vacuum leak, my guess. Normal operation: Pump brakes several times to vent any vacuum. Push down on brake pedal normally and hold. Turn motor on. Pedal should drop slightly. Go listen around the master cylinder while someone pumps the brake with the motor running. Hear any hissing? Quote Link to comment
ggzilla Posted November 2, 2013 Report Share Posted November 2, 2013 "brake pedal was stuck" - replace the booster. It is leaking vacuum which causes all those other symptoms. Quote Link to comment
pondking Posted November 2, 2013 Author Report Share Posted November 2, 2013 pedal did not drop slightly hissing sounds from inside pedal clicks now too what would a good replacement? because i think i have a z's and i heard something about the 280zx ones and by the way this problem is on a 610 Quote Link to comment
