GORILLARILLA21` Posted November 2, 2013 Report Share Posted November 2, 2013 Can I use the 510 canisters on the 280zx master? Or are the designs different in the way that it pushes the tube inside down? Also, where can I find the piece that connects to the brake that compresses the piston in the master? Or just the name of it so I can find it on rock auto? Thanks a lot. Quote Link to comment
datzenmike Posted November 2, 2013 Report Share Posted November 2, 2013 You mean the brake vacuum booster AKA power brake. Yes the 510 booster will fit only the '79-'81 zx master cylinders with the vertical mounting bolt pattern. The push rod that fits into the master should be attached to the brake booster. Quote Link to comment
GORILLARILLA21` Posted November 2, 2013 Author Report Share Posted November 2, 2013 Alrighty, thanks mike. Quote Link to comment
