Engine Porn (beyond ... saturation)
  • Replies 4.9k
Yeah this is Rob marketing Z-Car as usual. Their still testing and being conservative, but Rob's a businessman and always ready to toot his own horn. Rebello L32's make more HP with a SOHC head, so... That said, it's obvious this head has massive potential, and it's exhaust note sounds like an orgasm.
I also suspect some gears by how fast it climbs through first. It sounds fast but the video doesn't really impress as much as it should and the speedometer isn't working, maybe on purpose? That is understandable. Acceleration is best when experienced.
The first dyno doesn't rev as high as the last. You can see a tach on the monitor and it's either above 7k or above 8k. No where near revved out on the street.
  • Thanks 1
Definitely Mike. On the dyno as it's running through the gears, the trans has a crazy tight ratio. At the beginning when it's climbing through 2nd and 3rd on those narrow surface streets, my guess is he's going about 45-50 mph and ringing it out to almost 7k. I wouldn't be shocked if the Dif ring gear was in the mid 4s. Unless they plan on reaching for a 12K redline, none of this makes sense.
For perspective, at 7K in 3rd, my 510 is approaching 90 mph in this vid. And yes, I'm tooting a horn for the old SR20 510.
4 hours ago, datzenmike said:
 Windsor's don't do 7k.
Product placement.
195/60R14s 4.11 and 1.361 3rd gear.... my 710 would be going 86.44 at 7k
I had one that did stuffed in a Sunbeam Tiger of course it was no where near stock roller cam etc. 😁
  • 3 weeks later...
  • 3 weeks later...
On 6/20/2021 at 7:16 PM, datzenmike said:
 The 348/409 heads do not have combustion chambers. They are flat with valves at right angles.
Chevy 348, 409, & non-porcupine 427's do have combustion chambers. They are true 'wedge' combustion chamber engines with the combustion chamber located in the top of the cylinder bore and not in the head like most engines. The top of the engine block is machined at an angle to the cylinder axis; there is a wedge plate that is placed between the block and boring bar to bore them. As you say the underside of the head is totally flat and the axis of the valve stems are at right angle to the head lower surface.
Edited by difrangia
When I was in high school in the mid '60s there was a legendary '55 around town owned by Ken Zayet that had a 409 in it. Here I wasn't old enough to drive but I remember this guy's name after 55 years. He was doing some work on the stage in the auditorium having graduated maybe 5 years previously. He wore a T shirt with pack of cigarettes rolled up in the sleeve, black greasy hair and black leather pants like Jim Morrison. Cool as shit.
There were a couple of cars with transplanted 409's that were a legend around our country-hick area in east central Oklahoma in the early-mid 1960's. One a beautiful adobe beige 57 Bel-Air Hardtop with a 409 and an old Ford straight axle. I think the guy that built it then still has it and has changed it back to original A-Frame suspension and don't know what he has in for an engine now but he still has it stored.
Other one was a Ford T Roadster pickup with a 409 pirated from a brand new 1964 two-door Biscayne that the guys dad bought just to get the engine. That machine was all engine. The young man flipped the pickup one night with it full of friends in the bucket and short bed. One of the kids got killed in the crash. The kid later joined the Air Force and became a Captain and a fighter pilot. He crashed a fighter and died on an unauthorized flight detour to his hometown. His dad was watching him fly over when he went down in 1969.
Edited by difrangia
  • 4 weeks later...
3 hours ago, datzenmike said:
Thought the Pontiac OHC came with a 4 bbl.
There were several versions of the Poncho SOHC 6. There were 2 displacements a 230 and a 250. The 230 with the single barrel carb made a whopping 165 hp and the hottest 250 with the 4 barrel made 230 hp.
  • Thanks 1
