Gary
ratsun workshop project
hhhi
after moving to a new place with some room out the back i thought itd be a good idea to make a workshop so i can continue building ratsuns and things. 620 is still where i used to live and hasnt seen progress in a while, i really miss working on it. it and everything else, ive been away from tools and stuff for ages
so this is a build thread for what ive been working on for the last 9 months or so
started out like this, thats the fleet :D just missing the 620 and a cressida, and my current daily. an extra manly mazda demio/bubble
some dudes came round to bore some holes and make some mud
then the shed turned up a couple weeks early
then some formwork and some reo
then some concrete, then saw cuts
  • Like 10
Share this post
Link to post
then started putting up shed;
and this is what its up to now
not too far before moving in
  • Like 5
Share this post
Link to post
nice!
Share this post
Link to post
just curious, will you be putting up a vapor barrier / insulation ? Other wise it's going to be raining moisture from  gathering on the inside of the metal panels.
nice work, what size is the slab. I got to get me one of these, some day.
Share this post
Link to post
Looks great.
I wish i had mine built out of steel like you did,  i'm always worried about torch cutting and welding when i know i'm going in for the night.,, if i ever build another it will be.. (( pipe dream  :crying: ))
:thumbup:
Share this post
Link to post
thanks fellas
slab is 6" in the middle and 4" either side, 9m by 7.6m. i want to try insulate shed for noise to help keep neighbors happier so sealing it is reasonably important for that. not sure how to go about it yet but when its up ill see what has to be done. gotta be careful with not making it flammable, lots of welding and cutting and things to be done
at work to cut down noise from crane powerpacks theyre contained in steel panels filled with fibreglass, the inside walls are perforated. i saw the same thing at school in a grinding room so ill try figure that out
Share this post
Link to post
Looks great.
:thumbup:
i initially was going to comment how cool it was that they were using steel instead of just wood, but then some of the finish of the metal kinda resembled aluminum so i assumed it was aluminum.
sooo... is that steel or aluminum beams that we see
Share this post
Link to post
I'm not sure they make aluminum sheds of that size (I could be wrong, of course), but I'm pretty sure it's galvanized steel.
Share this post
Link to post
youre right. i was confused. i was associating the look of galvanized steel with aluminum for some reason ><
Share this post
Link to post
yep all steel. the frame is galvanised steel, its all made of sheet pretty much. from 0.9 to 1.9 depending on which section. i thought of making my own but engineering it might become important later so the costs there already make that idea too expensive. im jealous as of the US, you guys can get away with so much more without bullshit regulation than this place. cars and sheds alike no doubt
ive got one of these waiting to go in, just need to finish the roof first cos the lift isnt weatherproofed. this pretty much had to be to australian standards too, worksafe approved etc :\ it jjjuussssttt fits :D
ive made a pretty complete model in sketchup before i put most of it together, but also did a less detailed one to get an idea of where everything is going. ive planned a mezzanine toward the back to hold a bunch of engines and transmissions ive got spare. theyre hard to store so i figured this would be the most effective way. room underneath for more datsuns
  • Like 7
Share this post
Link to post
Happens to the best of us man! I only thought it was most likely galvanized because I've helped build one before.
Freedom only matters if you can use it- at least you got a job that allows you to pay for all that in the first place.
Share this post
Link to post
sober words, good point
Share this post
Link to post
weather has been getting in the way but getting there
frame for the door is up after some figuring out
i messed up the walls, the top rail was supposed to go on the roof so spent some time fixing that
also got the roof ready so i can fix the walls for the raised bit. might be able to get some of the top roof done tomorrow
Share this post
Link to post
That is a great looking building. Where did you get it and how much was it? (I realize your no where near me but would like to compare :))
Share this post
Link to post
lol your name broke forum quote code
was through a shed place, they figure out kits using various steel stock from whoever supplies them. this one was from bluescope lysaght. theyve figured it out pretty good its coming together ok
this kit was about 10k, thatd probably translate to a lot less in the US tho
Share this post
Link to post
little more progress, would have been a lot more were it not for weather
some more sheets up, these were small and easy, the roof sheets managed to hold me up there ok
[imghttps://image.ibb.co/iSfHPF/14_10progress1.jpg]
damn weather. rain was on and off all day. this pic was taken same time, one side was beautiful, the other was rain and wind. perfect shed weather
this side done
was raining pretty consistent toward the end of the day, so i put these roof rails together at the right length ready for the top roof. still dunno how im going to do that
also since it was undercover i fitted some of these, kind of a draft/weather seal. i just hope it keeps out spiders
Share this post
Link to post
got a little more done today, was supposed to rain hard all day today but turned out cloudy and warm and kinda nice
screwed the other wall down proper and sheeted other side of the step up
then measured out the outer top roof rafters since thats all i could reach. managed to get them screwed down nice and figured out they were strong enough to have a ladder lashed to them so i can reach the rafters to go in near the peak. hopefully works out that way, i dunno how else to do it without spending money
Share this post
Link to post
Looking good! I'm very close to putting down a deposit on my own shed, going skillion roof though, not barn style. I bet the neighbours behind you will be wrapped with their new view, haha.
Share this post
Link to post
nice! home workshops are best workshops. wasnt much of a view to begin with, probably better for them cos more shade. no skin cancer for them
weather and overtime have been holding things up. today was pretty good. the last two rafters in
started on the roof and got it all up, just needs to be screwed down proper. the plastic panels dont line up to the ones in the other roof bits, i call it character
lookin better, not too far to go
ive got a lockdown weekend coming up, should get the shed done over those days off but ill see how it goes
  • Like 3
Share this post
Link to post
This is awesome man. I dream of a place with a shop like that with a lift in it.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
