sreams
Just finished my RL411 5-speed swap... learned some things
There has been some discussion about how swapping a Roadster 5-speed into an RL411 results in the shifter being too far back. I think I figured out -the- solution for this during my install.
I was looking closely at the shift mechanism on the 5-speed, and at pictures of other Datsun transmissions, and I started thinking maybe the "arm" that receives the shift lever could be flipped around 180 degrees. Well, it can. The result is a shift lever that is about 2" further forward:
This does result in the shift lever leaning forward too much, but a bent lever from a different Datsun (not sure which, actually) solves that easily. This can be seen in the above image. With the bent lever, metal and plastic "washers" are needed to keep it from spinning with side-to-side movement. I found an Ebay seller in Mexico who manufactures these. They can also be seen installed in the above image.
With this setup, a 280z inner shift boot works well (along with some sheet metal plate I cut to mount it to):
This cuts down on noise nicely. Finally... after researching what some of the 510 guys had done, I settled on a shifter console from an early 90s Honda Civic:
I plan to go with a nicer shift knob when I find one. The whole setup works beautifully, and the shifter comes out -exactly- where I want it. Hopefully others can benefit from what I've found.
-Scott
  • Like 4
Share this post
Link to post
Now that's Ratsun, right there.
Share this post
Link to post
If that works, excellent  job. I think it is ERIC B that was doing a bastard 5 speed gearbox conversion. yours seems to good to be true hopefully not.
Share this post
Link to post
Well... I'm driving the car now, so no need to hope. It works.
Eric's solution was for a 4-speed, not a 5-speed. The RL411 4-speeds are hard to come by, so he found a way to basically make one by combining two transmissions.
There is no way to shorten a Roadster 5-speed, but now it appears there is no need to.
-Scott
Share this post
Link to post
Great work! Makes me think that I might do that someday to my RL411. I'll be keeping my eye out for a Roadster 5 speed tranny.
Share this post
Link to post
I didn't think there was a difference between the roadster 4 speed and the 411 SSS 4 speed
-Scott
Share this post
Link to post
There is. The roadster 4-speed is longer. Here's Eric's thread on how to modify it for the 411:
http://community.ratsun.net/topic/32256-r16-411-4-speed-trans-build/
BTW... I'm pretty sure my "flip the shifter arm around" solution would not be sufficient with the roadster four speed. The 4-speed roadsters have their shift levers further back than the 5-speed roadsters do, oddly enough. But then... who wants 4 gears when you can easily have 5?
-Scott
Share this post
Link to post
yes if you were refeering to me... not sure where the "b came from.... ERICH P? my setup was to build a proper length 4 speed fo someoen just trying to manual swap a auto car. the roadster 5 speeds can get a lil pricey so i went 4 speed since the length was an issue and i wasnt interested in spending the money at the tiem to try and make it work. the sd22/25 5 speed trans fits perfect too..... just need a short case 2wd one and they arent that common form what ive seen
Share this post
Link to post
In order to save at least some money, the trick is to get a later Borg Warner 5-speed with brass synchros. The early roadster 5-speeds with steel synchros are more desirable for the roadster guys, and so cost more.
-Scott
Share this post
Link to post
Hi,
I may have a line on a 5 speed transmission from someone on the 311s.org site. A question from the seller, though:
Do you have the correct transmission cross member, flex plate and flywheel? I have these for sure ready to ship. The first two are different on the R16 and U20 engines.
How could I find this info out?
Thanks!
Share this post
Link to post
The back plate on the motor is twice as thick for the 5spd vs the 4 speed on an R16.  You can double up the plate if you don't have one off of a U20.  If you don't use the thicker plate you run the risk of messing up the thrust bearings.  Been discussed to death on 311s.org.
Share this post
Link to post
For the Roadster, the cross member is different. It either steps up or down for the 5 speed. I can't remember which off hand. There are rumors of making the 4 spd member work by flipping it over. Make sure that you get the correct arm for the throw out bearing also. 4 speed one is different.
Share this post
Link to post
I am a week or two away from stuffing a R20 stroker and 5 Spd into the Blackbird. I will fully document that process complete with pictures and cuss words.
Share this post
Link to post
Yeah, IIRC there's an old thread or two on folks modifying the 4-speed mount to work with the 5-speed tranny. All of this is moot because those mods are for the roadster, which has a frame and a transmission cross-member. Mostly irrelevant for the uni-body 410/411. Either way, you're fabricating if you don't have the stock 411 4-speed (Hmmmm.......I should probably sell mine).
Share this post
Link to post
Pretty sure I have at least one in the 32 Apple boxes of parts that came with the Black Bird. The PO never had just one of anything,as far as I can tell. Not to mention a bunch of Roadster parts that got thrown in for good measure.
Share this post
Link to post
Trans bigger than Alan's apple boxes. I gotta come down and go through those boxes with you........-AFTER- I get the roadster on the road.  B)
Share this post
Link to post
what did you do on the roadster 5 speed about the speedo cable?
Neely
Share this post
Link to post
Hey guys is it just me or are these images not availae? Was interested in info for a swap .
Can't view pics
Share this post
Link to post
I think they are long gone.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
