a14 brakes feel spongy
ElephantPrint
  • Replies 3
Adjust the rear drums. Too much travel eats up pedal travel to move them.
I have a problem with my brakes they feel really spongy loose, my brake master cylinder is new so is my brake booster. I checked all brake cylinders and all are fine none are leaking. Could my proportional valve be bad?
I don't think Nissan uses a proportioning valve. Instead the size of the rear cylinders is engineered/designed larger or smaller to compliment the master and bias braking to the front. In other words when the brakes were tried and the rears locked up too soon they simply put smaller wheel cylinders on to reduce braking effectiveness.
