Fuel gauge at constant empty....
Sphynx88
I grounded the yellow wire to the unit and it went up to full. I tried regrounding the black wire and it still won't move from empty (yes there is gas!).
Does this mean the float and sender are bad or is there something else to try?
By regrounding the black, I tried just grounding the sender, the black wire running all the way up and regrounding both. I am going to go out, sand down some metal to get the best ground I have but have a feeling it won't do much.
  • Replies 1
When I pulled the float out of mine (because the gauge wasn't moving) it was rusted solid. After 2 hrs. with a wire brush metal sand paper (fine) and lots of steel wool and WD40 all the rust was gone and my float gauge and fuel gauge worked as they should  :). When your gas is below the float gauge pull it out and see. If you've got rust to work off be careful as there is a VERY thin copper wire that runs along the gauge, you dont want to break that (I didn't see it till I had half the rust off). Good luck!
