jhk722 Posted September 6, 2013 Report Share Posted September 6, 2013 Cannot quite figure out what is wrong. I cant pull it and the lever stays up...But the brake doesn't engage. Any ideas? Quote Link to comment
Dguy210 Posted September 6, 2013 Report Share Posted September 6, 2013 Cannot quite figure out what is wrong. I cant pull it and the lever stays up...But the brake doesn't engage. Any ideas? Broken cable, too much slack, or something wrong with the cable setup or brake drums. As the cables age they do get more slack, there is usually an adjuster you can tighten to reduce the slack if it is not already maxed out. Quote Link to comment
flatcat19 Posted September 6, 2013 Report Share Posted September 6, 2013 Have you opened the rear drums to see if the arms are hooked up? Or gotten under to look at the cable? Quote Link to comment
jhk722 Posted September 6, 2013 Author Report Share Posted September 6, 2013 Haven't looked yet. I did the rear breaks but didn't think to look to see if it was hooked up. But ill check both of those. Quote Link to comment
flatcat19 Posted September 6, 2013 Report Share Posted September 6, 2013 Haven't looked yet. I did the rear breaks but didn't think to look to see if it was hooked up. But ill check both of those. How do you not know if they're hooked up if you did the brakes? You need to remove the ebrake actuator from the old trailing shoe to install a new one. 1 Quote Link to comment
