nbesheer Posted August 13, 2008 Report Share Posted August 13, 2008 Okay so I pulled an Electronic ignition from a 1980 720 and a coil from a 280ZX since the one on the truck was gone/hard to find. Where I am stuck is there is this little condenser looking thing on my 610 that screws into the strut tower and connects to the coil. what I need to know is if it connects to the positive, negative, or if I even need it ? Thanks for any help you can offer. Quote Link to comment
datzenmike Posted August 13, 2008 Report Share Posted August 13, 2008 Don't need it I would think. Quote Link to comment
mklotz70 Posted August 13, 2008 Report Share Posted August 13, 2008 neg side if you did Quote Link to comment
comply Posted August 26, 2008 Report Share Posted August 26, 2008 The ballast resistor? I bypassed mine. Quote Link to comment
Pacific coast Datsun Posted August 27, 2008 Report Share Posted August 27, 2008 If the 280 Z coil came out of a car with EI then yes you can bypass the condensor. You can also run the stock coil & keep the ballast hooked up. The EI coil will be taller,& wider than a points coil. Quote Link to comment
racerx Posted August 27, 2008 Report Share Posted August 27, 2008 Purpose of condensor is min. burning out your points and since you are converting to Elec. distributor then I don't think you need it. If it is ballast resistor then you need it, I assume, since this reduces voltage. Quote Link to comment
datzenmike Posted August 28, 2008 Report Share Posted August 28, 2008 Don't need it I would think. Well I checked, and there is a condenser on the '78 (remote igniter) and the '79 (matchbox) also the '80 720 L20B. Maybe noise supression??? Quote Link to comment
racerx Posted August 28, 2008 Report Share Posted August 28, 2008 simply put a condenser stores current so that your points do not get burned out. Quote Link to comment
banzai510(hainz) Posted August 28, 2008 Report Share Posted August 28, 2008 the small condensors by the coill are not needed if going to a Pertronix or Nissan EI. Quote Link to comment
zerow Posted August 28, 2008 Report Share Posted August 28, 2008 There are two condensors in a typical points system: 1) at the side of the points distributor, like racerx mentions, for storing and releasing electrical current. 2) at the coil, like datzenmike mentions, for noise suppression from the coil and associated electronics. Most modern radios can take care of the noise, but I remember when older radios could not. It was like a tach for the blind. :cool: Quote Link to comment
mklotz70 Posted August 28, 2008 Report Share Posted August 28, 2008 Well I checked, and there is a condenser on the '78 (remote igniter) and the '79 (matchbox) also the '80 720 L20B. Maybe noise supression??? Is is connected to the neg or pos? Quote Link to comment
datzenmike Posted August 28, 2008 Report Share Posted August 28, 2008 POS to the condenser (capacitor) to GROUND Quote Link to comment
mklotz70 Posted August 29, 2008 Report Share Posted August 29, 2008 then it was definitely in there for noise suppression. Quote Link to comment
