BOZO Posted August 28, 2013 Report Share Posted August 28, 2013 Does anybody have the dimensions (ID, OD, length, shoulder thickness) for the bushings that fit between the rear springs and the rear shackles on a 1974 620? After a lengthy search for replacement bushings, I have come up empty handed. So I'll make some... probably from UHMW, ZL-14, Teflon, or Delrin. Some dimensions or a diagram would save me from having to tear into the assembly until I have the parts ready. BUT, if anybody knows where I can find the original rubber ones that fit my year of truck, I would appreciate a hookup on that. I have been able to find bushings for later years, just not the 74 which is a bit different. Quote Link to comment
Dawa Posted August 28, 2013 Report Share Posted August 28, 2013 i got all the info you would need for the 73 620, IF its the same as the 74 including the original nissan part number, which is still available through nissan (i called and had them check) ^edit: sorry i had actually called them about the 720 bushings, which are still available check this out and see if its any help http://community.ratsun.net/topic/57051-dawas-720-leaf-springs-into-620-swap/ Quote Link to comment
datzenmike Posted August 28, 2013 Report Share Posted August 28, 2013 The double pair at the back (8 in all) are 55046-07200 and fit ALL 620s through '77 The fronts (one each per side) are 55045-B5000 and fit all years of 620 Quote Link to comment
kelowg Posted August 28, 2013 Report Share Posted August 28, 2013 energy suspension should have them too Quote Link to comment
Dawa Posted August 28, 2013 Report Share Posted August 28, 2013 i dont think ES has bushings for the 620. only the 720/d21(hb) Quote Link to comment
BOZO Posted August 28, 2013 Author Report Share Posted August 28, 2013 Thanks for the info guys. The Nissan #'s I had already copied from one of Datzenmikes earlier posts along with some NAPA #'s from another post. I didn't realize these #'s would cover a 74. And Dawa's post was already tagged in my Datsun files on my computer so I can refer to it when I start on this project. Informed info like this can save a fellow a lot of headaches Quote Link to comment
