HAM8URGER Posted August 13, 2013 Report Share Posted August 13, 2013 Ok so I have a line on a good deal to have full custom rotors made but need a little info. Here's what I have: 71 510 2 door Z32 calipers front and rear 280zx front struts and hubs 15" wheels The ability to make brackets I know the z32 conversion to 280zx front strut question has already been asked several times but I havnt seen anyone ask about custom rotors. What specs do I need? Rotor diameter(11"?), rotor thickness(30mm?) center bore? Height? Any help will be appreciated and be put into immediate use Quote Link to comment
Draker Posted August 13, 2013 Report Share Posted August 13, 2013 Depending on the calipers.. the front are either 30mm or 26mm. There are two different versions for the Z32. Quote Link to comment
HAM8URGER Posted August 13, 2013 Author Report Share Posted August 13, 2013 Mine are from an r33 skyline, same as turbo z32. 30mm I think but not 100% Quote Link to comment
mklotz70 Posted August 14, 2013 Report Share Posted August 14, 2013 Are you trying to make them captured or non-captured? Quote Link to comment
HAM8URGER Posted August 14, 2013 Author Report Share Posted August 14, 2013 Are you trying to make them captured or non-captured? you mean for bleeding? Quote Link to comment
mklotz70 Posted August 14, 2013 Report Share Posted August 14, 2013 captured rotors are the kind that bolt onto the back of the hub......non-captured slip over the outside. I'm guessing you're referring to something that mounts up like stock.....which would be captured. Quote Link to comment
HAM8URGER Posted August 14, 2013 Author Report Share Posted August 14, 2013 captured rotors are the kind that bolt onto the back of the hub......non-captured slip over the outside. I'm guessing you're referring to something that mounts up like stock.....which would be captured. Yes Quote Link to comment
mklotz70 Posted August 15, 2013 Report Share Posted August 15, 2013 If you got on rockauto.com and look up the rotor that fits your hub, you'll find a pic with the specs you need to make a custom one that fits the hub. You'll still have to figure out the offset. Quote Link to comment
Son_of_a_Datsun_Guy Posted September 1, 2013 Report Share Posted September 1, 2013 Edit: my post was not really relevant after re reading original post. Quote Link to comment
