I like coupes! - Pictures of Bluebird Coupes
carterb
  • Replies 1.6k
does anyone know where to get this type of bulb? EDIT: nevermind. I found it!
http://www.replacementlightbulbs.com/lamph7680x.html
I know its a spot light, and usually 80+ watts!! but I can only find them in 6"
Or any smooth reflector and clear lens that will fit.
thanks,
Saw those on a 510 once. Was told they are aircraft landing lights.   :confused:
EDIT: That link you posted says 5.75? That should be the right size.   ^_^
Voltage: 13V, 13 Volt Volts
Amperage: 6.15A
Glass: PAR46, PAR 46
Base: Screw Terminals
Beam Spread: Spot, Spotlamp, 6.5°
Filament: C-8, C8
Average Rated Life: 300 hours
ANSI Code: H7680X, H7680-X
Maximum Overall Diameter: 5.75"/146mm
Maxumim Overall Length: 3.75"/95.2mm
Beam Spread - Horizontal: 6.5° - 10 %
Beam Spread - Vertical: 6.5° - 10 %
Maximum Beam Candlepower: MBCP 230,000
Special Feature: Infrared, HIR
Bluebird Factory Shots
1969 Base Model Coupe:
1969 Bluebird SSS Coupe
1970 Bluebird Sports Coupe
1971 Bluebird 1800SSS Coupe
the last picture showing the interior. Anyone know what fabrics were used by Datsun at that time?
