TheShagginWagon Posted July 22, 2013 Report Share Posted July 22, 2013 Just picked up these from the Eagle rock swap meet yesterday. They are 14x6 and Im just trying to figure what size tires to run. On my last set of rims I ran 185/60 falken Ziex's all around on 14x6.5's. On those they had a mild stretch and I liked the look of it but if I run stretch on rims on 6" wide rim.... is it that too narrow of a tire? What do you guys think? It's going to be lowered, so if anyone with a lowered wagon or semi lowered 510 sedan feel free to throw up some pictures of what you run. Thanks in advance Quote Link to comment
Dawa Posted July 23, 2013 Report Share Posted July 23, 2013 well if you ran 185s on a wheel that was .5" wider, you should be fine running them on your 6"s http://www.rimsntires.com/specs.jsp use that site to compare/contract old and new set ups. remember that you could be raising/lowering your car as well as adding/reducing fender gap/clearance as you go up/down on tire sizes Quote Link to comment
TheShagginWagon Posted July 23, 2013 Author Report Share Posted July 23, 2013 well if you ran 185s on a wheel that was .5" wider, you should be fine running them on your 6"s http://www.rimsntires.com/specs.jsp use that site to compare/contract old and new set ups. remember that you could be raising/lowering your car as well as adding/reducing fender gap/clearance as you go up/down on tire sizes This link is awesome, Thank you Quote Link to comment
datzenmike Posted July 23, 2013 Report Share Posted July 23, 2013 Never buy rims and then figure out how to make them fit. Find out first how much positive or negative off set you can get away with, then look for rims in that range. See these rims? No amount of fixing is going to make them work on my 710. They stick out about an inch and a half on each side. Even at stock height they bottom out on the edge of the wheel well on bumps. No worries they were free and I only used them so I could move the car around at the body shop. Just imagine if a liked them ( :sick: :sick: ) and paid big bucks for them. How heartbroken I would be. How I might plasma cut the wheel wells and throw on some e-Bay flairs. ( :sick: :sick: ) Quote Link to comment
TheShagginWagon Posted July 23, 2013 Author Report Share Posted July 23, 2013 Never buy rims and then figure out how to make them fit. Find out first how much positive or negative off set you can get away with, then look for rims in that range. My previous set of rims were almost the same size. 14x6 versus 14x6.5 and the offset +10 versus +15 not a real drastic change. So I could probably run the same size tires that i had on the previous set. I was just wondering if someone had any other ideas Quote Link to comment
TheShagginWagon Posted July 23, 2013 Author Report Share Posted July 23, 2013 There was never really any doubt in my mind that they would fit well when i bought them, and now putting them on at home they fit just fine Quote Link to comment
datzenmike Posted July 23, 2013 Report Share Posted July 23, 2013 Good, not every one does this. Quote Link to comment
rusty12ver Posted August 7, 2013 Report Share Posted August 7, 2013 Those look good, a 185-55-14 on a 6" will have a slight bulge, I ran a 185-60-14 on a 6" wide, then went to a 185-55-14. 14x6" +15. The rolling diameter of the 185-55-14 is very close to a 195-50-15. 1 Quote Link to comment
nb6179505 Posted August 7, 2013 Report Share Posted August 7, 2013 where can you find 185 55 14's or even 185 50 14's? Quote Link to comment
DatMo Posted August 7, 2013 Report Share Posted August 7, 2013 where can you find 185 55 14's or even 185 50 14's? ebay, tire rack. discount tires/ here's a set I was planning to buy. it's $310 shipped to me. http://www.ebay.com/itm/2-New-185-55-14-Roadstone-N2000-Tires-/400545983411?pt=Motors_Car_Truck_Tires&fits=Section+Width%3A185%7CAspect+Ratio%3A55%7CRim+Diameter%3A14&hash=item5d4266abb3&vxp=mtr Don't cheap out on tires! Quote Link to comment
TheShagginWagon Posted August 7, 2013 Author Report Share Posted August 7, 2013 Don't cheap out on tires! Too true Quote Link to comment
nb6179505 Posted August 7, 2013 Report Share Posted August 7, 2013 yeah man, those are so pricey. Ive heard that because 14s aren't too popular, your retail tire stores have stopped buying them to sell 1 Quote Link to comment
rusty12ver Posted August 8, 2013 Report Share Posted August 8, 2013 Does yoko still make the 185-55-14? Quote Link to comment
DatMo Posted August 8, 2013 Report Share Posted August 8, 2013 those ebay tires dont seem to be bad to me and form reviews theyre what you pay for Quote Link to comment
