lynchfourtwenty Posted August 7, 2008 Report Share Posted August 7, 2008 talkin about in my 620.. 77.. stock 4spd.. im talkin no mods or nothin just in an out.. Quote Link to comment
moparvwfreak Posted August 7, 2008 Report Share Posted August 7, 2008 dont see why it wouldn't. a 4spd for a 4spd right??? that looks to be the same as mine in my 73. Quote Link to comment
lynchfourtwenty Posted August 7, 2008 Author Report Share Posted August 7, 2008 4 to 5 it came out of a 83 maxima Quote Link to comment
]2eDeYe Posted August 7, 2008 Report Share Posted August 7, 2008 77 should be a direct swap. Crawl under your truck and throw a tape measure on your 4 speed. If it's the same length your good to go. Quote Link to comment
datzenmike Posted August 7, 2008 Report Share Posted August 7, 2008 The '73.5 to '79 used the long tail 4 spd., same length as the 5 spd. Measure them... should be 31.5" long. You'll probably have to use the Maxima shifter with it. Quote Link to comment
Bleach Posted August 7, 2008 Report Share Posted August 7, 2008 yup! I used a 1982 280zx 5- speed in a 1978 620 truck. Bolted right up, no mods at all. I did a short 5th gear to tall 5th gear swap! :D (had to work on the clutch anyway) Quote Link to comment
moparvwfreak Posted August 7, 2008 Report Share Posted August 7, 2008 well next time give some specs on what it is. now i feel stupid. Quote Link to comment
lynchfourtwenty Posted August 7, 2008 Author Report Share Posted August 7, 2008 lol sorry mopar, its hard to measure tranny while its in the truck cause all the crap.. but they visually look identical.. as for using the maxima shifter.. i my other shifter will work fine.. they're the same kinda setup either way i wouldnt mind if i had to.. we're going to take that tranny out of the purple people eater an put it in my truck some time in the future.. we located a t5 for the zx and also an extra turbo motor.. it runs but has some issues.. im sure if we used all the parts thats on his current motor the other would run fine.. but the plan is to build the spare one up Quote Link to comment
datzenmike Posted August 8, 2008 Report Share Posted August 8, 2008 It'll work. If the one on the ground from the Maxima is 31.5" go for it.!! I can tell by looking at the picture that you're OK. Quote Link to comment
lynchfourtwenty Posted August 8, 2008 Author Report Share Posted August 8, 2008 cool, thanks guys! Quote Link to comment
Llittle_Llama Posted August 11, 2008 Report Share Posted August 11, 2008 so a maxima 5 speed will work in place of a 280z tranny? Quote Link to comment
lynchfourtwenty Posted August 11, 2008 Author Report Share Posted August 11, 2008 280z yea zx yea prolly.. zx turbo no Quote Link to comment
