Twisted Images Bagged, Body Dropped, & Rotary Powered 510
  • Replies 663
  • 1 month later...
Sorry it's been a while since my last update- work and home life take priority over garage time lately!
I DID manage to rebuild the front suspension- new bearings and seals, new rotors, drop spindles, cleaned and painted the hubs, and built new upper control arms from plate steel.  I still have more modifications to make to the lower arm, and then it'll be cleaned up and painted as well.
206.thumb.jpg.4e1736ad28a862dbc45e1eb234307546.jpg209.thumb.jpg.6465b2bd682bf8460c56d04509f65ffd.jpg211.thumb.jpg.3747b3dcf079751de40831bf071fa15b.jpg212.thumb.jpg.8ce93444d0fb2f4dd238923f6a8eff97.jpg213.thumb.jpg.0a6fcded8e64d137904fb8b4dc67adf5.jpg
http://www.twistedimages.us/510/206.jpghttp://www.twistedimages.us/510/209.jpghttp://www.twistedimages.us/510/211.jpghttp://www.twistedimages.us/510/212.jpghttp://www.twistedimages.us/510/213.jpghttp://www.twistedimages.us/510/215.jpg
I also tried a product called Hot Tires from Duplicolor- it's a tire paint that's supposed to stay white and flexible- we'll see about that.  I think it looks alright on there- wish it was a more prestigious tire brand, but nobody else makes these little skinnies!
I've been saving my pennies, and I'm just about ready to pull the trigger on an engine and transmission.  THAT will get me ready for the next phase quickly, so there's still hope this car will see the road this year!
Edited by twistedimages
oics
I love love love this car, just read through this thread. Can't wait to see the finished project. I love what you said a few pages back and couldn't agree more. "First off, let me say that I acknowledge everyone's opinions. Fortunately, though, it's my car to build as I choose, and I'm not one to be swayed by other people's opinions. I know the car will be polarizing- that's why I'm building it! Some people will hate the frame, some people will hate the air suspension, others will hate that I've left it rusty instead of fixing the body and painting it... point is, it's never going to satisfy everyone, so I'll just keep building it to MY vision!"
I've been trying to save up to bag my 620, especially now that I'm petitioning for a =Sunset= chapter. I've also got a ratty 4 door 510 that I've considered putting on bags. Anyway keep up all the great work!
  • 1 month later...
Okay, I suck at updates.  So it's been a couple of weeks since most of this progress was made.  Let's get started...
To move the car to my friend's house, I needed to tack the front suspension brackets together.  My garage's electrical is on the opposite side of my house from the panel, so my welder can't be turned up far enough for a proper weld- happy to say my tacks kept it together long enough for the trip!
222.thumb.JPG.b6271c9ef73989fa6a8791bbbd1252a1.JPG223.thumb.JPG.0d1f2d915a671aa02f70bf25c9d197fb.JPG
http://www.twistedimages.us/510/220.JPGhttp://www.twistedimages.us/510/221.JPGhttp://www.twistedimages.us/510/222.JPGhttp://www.twistedimages.us/510/223.JPGWith a shrader valve to throw some air in the 'bags, I finally get to see what this suspension will do!
http://www.twistedimages.us/510/224.JPGI'll have shocks on there which will limit the upper travel a bit, but I'll have more than enough lift to get in and out of driveways.  I set the upper mounts higher than they need to be, too, so if I go to a taller tire later down the road I'll still be able to put the frame on the ground.
With the front suspension together, and some 2x6 boards braced between the roll cage and the rear arms, we loaded the car onto a trailer and headed to the workshop!
http://www.twistedimages.us/510/225.JPGI'm going to have to put some better air assist in the rear of my wagon if I'm going to use it as my tow rig- even with this empty shell the hitch was dragging!
We started fresh the next morning, with several items on the checklist:
First, the rear suspension needed to be moved forward just over an inch, so it lines up better in the wheelwells.  We braced up the frame, cut it free, then re-squared and welded it back into place.
http://www.twistedimages.us/510/226.JPGhttp://www.twistedimages.us/510/228.JPG
While Miles welded the rear crossmember fully into place, I pulled the front suspension apart so he could weld my brackets up properly.
http://www.twistedimages.us/510/227.JPGhttp://www.twistedimages.us/510/229.JPG
With that completed, we got started on measuring up for the rear frame section.  On the first stage of the build, we stopped the frame rails just behind the rear end because I still had a rusty trunk floor hanging in the way.  With that cut away a few months ago, we had all the room in the world to build out the rest of the frame.  I've been eager to get this done, since the entire rear of the car has been basically just hanging with no support!
Miles measured and cut some 2x3 box tubing and built the rails on his work table:
http://www.twistedimages.us/510/230.JPG
Then we squared them up in the car, tacked them into place, and leveled them out before fully welding them to the rest of the frame.
http://www.twistedimages.us/510/231.JPGhttp://www.twistedimages.us/510/232.JPG
I offered some additional weight to hold the rails in place as they were welded!
With the frame built and welded up, we laid out some cardboard templates for the upper rear airbag brackets.  The lowers are just flat plates welded over the spring pocket holes in the trailing arms, so we just had to make upper mounts to match the angle of the lowers.  With templates in hand, we went to my shop and cut them on our CNC plasma table- so much easier than hand-cutting!  A quick lunch break later, and we got back to the house to weld them in.
http://www.twistedimages.us/510/233.JPGhttp://www.twistedimages.us/510/234.JPGhttp://www.twistedimages.us/510/235.JPG
When I bring the rear tubing down to complete the roll cage I'll probably tie the brackets into it, just for some more strength.  After bolting the airbags in and running another shrader valve, the 510 was finally sitting on a complete suspension for the first time in years!
http://www.twistedimages.us/510/236.JPG
Just as I did with the front suspension, I made sure the rear airbags weren't fully deflated when the frame hit the ground.  This will allow me to run a taller tire later on without re-working the brackets, and it also means I'll be running a higher pressure at ride height.  My hope is that this will equal a slightly stiffer ride- we'll see how that works out!  In the meantime, the rear end has room to go even lower when the front of the car is lifted- I'm almost tucking the center cap!
The last item I wanted to address was the front clip.  We had just tacked some tubing to the front frame horns to hold the core support in place last time, but I designed and laser cut some proper frame brackets to mount it.  We cleared the frame of all of the old welds, lined everything up, and welded it back on.
http://www.twistedimages.us/510/237.JPGhttp://www.twistedimages.us/510/238.JPG
I have to machine some sleeves for the bolts to pass through before I fully box these plates, but for now it's holding the front end in place.  The fender gaps are nice, too, although I have some adjustment in the brackets if anything settles once there's more weight on it.
oics
  • Like 3
Apparently I tried to post too many pictures in one posting- so here's part two of the latest progress!
So, with all of that work completed, the 510 came back home.  Since then, I designed and cut brackets to tie the bumper brackets to the frame:
246.thumb.JPG.3cdc733255439ca401b61fd38973f25f.JPG247.thumb.JPG.68e377670d28eb79407d7d3a3f62b35a.JPG
http://www.twistedimages.us/510/246.JPGhttp://www.twistedimages.us/510/247.JPGhttp://www.twistedimages.us/510/248.JPGhttp://www.twistedimages.us/510/249.JPG
Now the rear end feels solid!  I still need to make brackets to attach the quarter panels over to the frame, but at least I don't have to worry about someone leaning against the trunk and buckling the entire rear clip!
Today, I went down to the shop and designed the brackets for the mustache bar, cut them on the plasma table, and mounted them to the rear end.  I'll tack them later.
http://www.twistedimages.us/510/250.JPG
So, I'm just about at the point where I need to build an engine for this thing.  I've got something in mind, and I'll pull the trigger once I sell my Toyota Pickup to fund it!
In the meantime, here are some more pictures of the suspension and how the car sits:
242.thumb.JPG.e841311bc6652c4ee089c5c7a8353751.JPG243.thumb.JPG.5e393712815342a6501a2988a9fcf8fc.JPG
http://www.twistedimages.us/510/242.JPGhttp://www.twistedimages.us/510/243.JPG
http://www.twistedimages.us/510/239.JPGCrazy positive rear camber at full lift!  Don't worry- I don't plan on fully lifting it for anything other than tire changes!
http://www.twistedimages.us/510/244.JPGhttp://www.twistedimages.us/510/245.JPG
244.thumb.JPG.0f799da2e6ec75e790623aa8dbaf5b62.JPG245.thumb.JPG.9f306deee7bdb91eb2106ae7fb836870.JPG
More to come as I find the time!
oics
  • Like 9
nice work man! cant wait to see a vid of it draggin frame!
No dragging on this one!! I went through a dragging phase with my 521 years ago, and now the cab is sitting on a pallet waiting for a new frame! I'm going to roll low, and the frame may contact the ground from time to time, but I won't be dragging down the road with this one!
  • 1 month later...
Yay- more progress!
I sold one of my other vehicles, which freed up some cash for this project.  And of course, right when I have cash is when all of the potential engine donors in the area disappear!  Fortunately, I did the opposite of what I normally do, held onto the cash, and waited until the perfect drivetrain showed up...
1989 Mazda RX7, S5 normally aspirated, with a handful of upgrades to boot.  Guy had the whole car for sale, and I was able to get him to sell just the egine and trans to me, meaning I've got my engine AND my wife doesn't have to see another shell sitting out front!  Win-win, if you ask me!  The added bonus was that I was able to drive the thing before the motor was pulled out- always a bonus, but especially with a rotary!
So, now the hunt is on for a few additional parts, and then I'll be mocking everything up into the car. In the meantime, I've stripped the intake manifold and all of the smog equipment off the engine, and it's ready for a deep cleaning and some paint.
Another key component came my way, and it's waiting for its turn to be bolted in:
R200 from a 280Z, which will be welded up sometime soon.  I'm also going to run a 240sx diff cover, since I have it here and just to be different.  I have to make the rear mount anyway, so what the heck?
I've visited The510Keeper a couple of times in the past month to help with a project of his, and I was handsomely rewarded with a nasty grille and front bumper.  I twisted the grille back into shape enough to get it mounted, but I'll need to modify some brackets to get the bumper on there.
So, that's the latest from me.  Still a huge list to check off, but I think it'll start moving quickly once the engine and trans are in place!
Since I'm updating, here's a couple shots of my office space.  My brother ( Wagdatto on here ) hooked me up with this awesome poster for my birthday, so I got it hung up at the shop
And here's the other side of my desk- Datsun Hot Wheels surrounding a photo from the 1998 Mt Shasta All-Datsun Meet (my first Datsun outing- the start of my madness!)
I should have the engine looking pretty in the next couple of weeks- I'll post more then!
  • Like 5
Get yourself an early 12a front cover(timing cover) and oil pan to make your install a whole lot easier. Can sit it lower in the car too.
With my Toyota front clip I'm not sure that'll be necessary, but I'll know more after I get it into the car to mock up. Thanks for the tip!
  • 1 month later...
Holy crap- a MONTH since my last update??  Oh, well- no excuses.  Let's dig in!
The big news all happened this weekend- my buddy Miles came over with the trailer, and off we went back to his house...
http://www.twistedimages.us/510/270.jpg
We squared up the engine and transmission in the engine bay, and decided to run it a bit hgher than usual to help gain more clearance for the header as well as the steering.
http://www.twistedimages.us/510/272.jpg
With the position decided, we broke out the cardboard and began making templates for the mounts.  The goal is to design a mount that will be easy to disassemble from both the frame and engine, so when the firewall and transmission tunnel are in you can still slide everything out.  My front clip will be removable, so that makes things a bit easier.
http://www.twistedimages.us/510/271.jpg
I converted our templates into dxf files for the CNC plasma table, spent an hour at the shop, and came home with these:
http://www.twistedimages.us/510/273.jpg
Miles threw down some welds after test-fitting,
http://www.twistedimages.us/510/274.jpg
And we built a transmission mount as well.
http://www.twistedimages.us/510/275.jpg
http://www.twistedimages.us/510/276.jpg
The trans crossmember was built to be removable, and I have an exhaust hole large enough for a v-band style pipe to pass through for later service.
With everything dialed in, we welded on the frame tabs, and mounted everything up:
277.thumb.jpg.9b1762fa035bd394e3661431926ab18b.jpg278.thumb.jpg.ed9a542cd1e65d13d961974f41f87b05.jpg
http://www.twistedimages.us/510/277.jpg
http://www.twistedimages.us/510/278.jpg
(Never mind the lug nuts holding this bracket on- I'll find some proper nuts eventually!)
http://www.twistedimages.us/510/279.jpg
http://www.twistedimages.us/510/280.jpg
http://www.twistedimages.us/510/281.JPG
Welding done, the car is back home!  I threw the front clip back on, and the hood just BARELY clears everything!
282.thumb.JPG.d3512c204aea79ec1d90880c2e4db429.JPG284.thumb.JPG.ff8b20846c031c8c1798d832d83910d7.JPG286.thumb.JPG.f93eccead0eb62fb24bb46bc36207271.JPG
http://www.twistedimages.us/510/282.JPG
http://www.twistedimages.us/510/283.JPG
http://www.twistedimages.us/510/284.JPG
http://www.twistedimages.us/510/285.JPG
http://www.twistedimages.us/510/286.JPG
Since I last posted, I also started collecting parts for the 13B.  You can already see the Racing Beat intake manifold with a 48mm Weber IDA, as well as a distributor from a 12A, to eliminate the CAS from the EFI system.  Also waiting for installation are an MSD 6AL2, three MSD Blaster coils, Holley Blue fuel pump, and a bunch of miscellaneous parts to build my exhaust header.  Now that the engine is mounted, I can start designing the firewall and hopefully get these parts onto the car before too much longer!
Oh, I also pulled the R200 apart, welded it up, and made a new bracket to mount it.  I swapped over to a diff cover from a 240sx, since it has fins and it was just sitting here!
http://www.twistedimages.us/510/287.JPG
http://www.twistedimages.us/510/288.JPG
More updates to come- sooner this time, I hope!
oics
  • Like 8
It's really great for one-off stuff. Laser is always cleaner, but for small orders it usually takes a week- that wasn't an option for this project!
Fwiw, if anyone has a need for parts just let me know. I do all of the programming and cutting on this table, and I'll be super-reasonable for fellow Ratsun members!
