hosestop@msn.com
Alleycatgarage So Cal shop
yAD8rsa.jpgsoShoUj.jpgLsQrUHV.jpgafzx6Oy.jpgQAGh4Ay.jpgcsxECFm.jpg More Datsun 521 love ,washed shiney bed with soap and water ,Vic removing extended bumper , drive by was Johnny from Napa auto in his personal truck.
  • Like 3
Share this post
Link to post
oh those polished rikens :cool:
Nice score on that blue one. Is the camper in good shape or did you get rid of it?
Share this post
Link to post
Dang, that's one sweet 521!!!  Even came with bias ply tires!!  Now that's a barn find!! Congrats.
Share this post
Link to post
The color has a slight teal in person color sanded bed rust stained slightly ,may clear or paint bed only.ngSlyey.jpgkE74lHQ.jpgnRbQEr8.jpg
  • Like 3
Share this post
Link to post
Camper had some dry rot bolts in floor busted out, thing was heavy and tall had fridge and two burner, gave it to estate sale buddy that called me . .oLFIhh6.jpg
  • Like 3
Share this post
Link to post
Please give some feedback on this mod + - 1974 Datsun 620 SR20DE NA swap .Removable tunnel for SR20De swap. ( Transmission gets caught under car with frame on 620 and 521 on SR swaps ,may have to pull motor for clutch job ,instead pull seat and tunnel ) installed in car ,Slightly taller , now shift boot lines up with hole and tunnel sealed and screwed down with stainless screws . can't get new shift boot over SR20 shifter damper thing may soak in hot water and lube , shifter fits better backwards in small cab . Built throttle cable with air line hose ,re-use 521 hardware drilled out old housing and use stock cable ends , gets clamped at firewall . Air pipe between throttle body and MAF measures 24" smooth bends shorter than stock one , last one ran smooth like this.OBquFhJ.jpgOCc9xBH.jpg5Y7EhiV.jpgMF0ZGVJ.jpg
  • Like 3
Share this post
Link to post
I'm glad to see that you got the tailgate with the blue one.
Share this post
Link to post
I can't do too much to blue 521 , bummed , stashed in back row of dead players , green 521 inside shop needs 6-8 hrs to get S13na running and as we all know must do customer cars first to get paid. Hey I am selling extended bumper.HnEK5d3.jpgyAD8rsa.jpg
Share this post
Link to post
t7g5q51.jpgJhOeB14.jpgAQyPQK3.jpgNxvSVIu.jpg 1974 Datsun 620 sr20de S15 runs needs a few minor stuff ex. lower pipe from 300zx l side and small stuff , 1967 Datsun 520 with L20b much work disc braked and sway bars.
  • Like 5
Share this post
Link to post
Scored this time capsule for a friend but he may be a little big for it ! we may fix everything new brakes and it started for a second as is , this was a Whittier blvd truck L18 SU s It may be for sale in two months , white car has S15 na also S15 Na truck is closer to complete if I worked on it today may drive to muffler shop.xOiB9zA.jpgOaWUMO5.jpg1zELeed.jpgJhOeB14.jpg
  • Like 3
Share this post
Link to post
Bluebirds we work on silver one getting new rebuilt mtr and engine bay paint has 219 and side draft 40s , maroon truck was running good then I parked and came back to a stuck valve so off with the head to machine shop.ze1OAzC.jpgjYe5Xxi.jpgbfA1aEG.jpgXoiw29P.jpgUv9GdIe.jpg
  • Like 5
Share this post
Link to post
Damn looks like you are busy that is good.
Share this post
Link to post
Got these cool old gauges at a swap meet (no bar codes so 80s ),mostly liked the angle all temp gauges electric mech. oil pressure , also last four swaps been SR20de  NA s.P5DHzQh.jpg93vy8SG.jpgfOO3EfF.jpgcYigQ8r.jpggwjALKi.jpg3NgZThc.jpg my car got some pieces painted getting it ready for sale soon.
Share this post
Link to post
The white 510 is the Jakal owned by a friend that passed a year ago , has many fibre glass parts, fully built with some nice stuff needs some floors patched small squares , has Z20 with big head and BRE manifold , some of the guys want to do a corporate car thing  so they get a chance to get on track ,tires mostly !.Yellow 510 wagon has sticker on rear window saying grocery getter , sr20det with big turbo and Ford 8,8 getting done . other shots of yard .
fObzwn4.jpgfObzwn4.jpghttps://i.imgur.com/68hciuA.jpg]gRSTlkR.jpg46MxNzI.jpgc39yUNu.jpg
Share this post
Link to post
Grocery getter has tuner fonts on list ,See greddy and Pirelli,hks.
Share this post
Link to post
Ok its been almost a year and recently picked up a 1992 Dodge w250 5spd 4x4 Cummins diesel for a tow rig and road dog .
Share this post
Link to post
 Twenty seven years old-  we are restoring this good old truck has 167k miles (they say is barely broke in with one of these 12 valve Cummins motors  )Gertrag trans is a + also, no rust ,also has made me want to paint in parts at this time .We replaced leafs ,shocks and a longer steer arm for 4" lifted leafs ,also rebuilt steer coupling ,most parts are cheap so far .Maybe best truck ever made for tow ect.Also cut the snow plow mount off for less weight and make as stock as possible much better raised  also !
Share this post
Link to post
I am aware of dowel pin problem , I believe has been done already will check records ,have most all the way top window sticker that was 26,000 new with extras ,has lsd front Dana 60 I believe ,says it on sticker.
Share this post
Link to post
