BlackBird620 Posted June 28, 2013 Report Share Posted June 28, 2013 OK so I went into a tire and rim shop out here and found a set of 17s that I had my buddy Photoshop onto the 620 I plan on running 215/45s up front and 235/50s in the rear but I'm not sure of the offset I need on the rims the rims only have 3 different offsets from the dealer -22,0,+22 can anyone shed some light on this for me since I know nothing about wheels 1 Quote Link to comment
datzenmike Posted June 28, 2013 Report Share Posted June 28, 2013 Well at last some common sense. Find out what fits first. Most just fall in love with them, then buy them then try to make them fit and start crying. http://www.1010tires.com/Tools/Wheel-Offset-Calculator Here's one that shows the tires too. http://www.rimsntires.com/specs.jsp Quote Link to comment
]2eDeYe Posted June 28, 2013 Report Share Posted June 28, 2013 You might also measure one of your wheels to get a good real work comparison. Quote Link to comment
Dawa Posted June 28, 2013 Report Share Posted June 28, 2013 i can get you a decent set of 17s from japan starting at about $600 shipped 17x8 0 offset is about perfect. im running 8.5 -10s on my 73 620 Quote Link to comment
Dawa Posted June 28, 2013 Report Share Posted June 28, 2013 here are how my 16x8.5 negative 10 offset look on my truck as for tires im running 225/45 up front and 245/45 on the rear. check out this site to compare and contrast http://www.rimsntires.com/specs.jsp in comparison, my 225/45s are obviously 10mm wider than your 215s, and only 'shorter' by .7" (my 23.9 circumference vs your 24.6) which is only .35" in radius. ive lowered my front close to 4 inches so you def got room up front. in the rear again im obviously 10mm wider in the tire, but youre now 1.7" taller. (24.6 vs 26.3) or .85" in radius. i got 3" blocks on the rear and im good, so i think youll be good to i will add that my rear tires do scrape, even after some modest hammering on the inner lip of the rear fenders. but again im 10mm wider than you.... what wheel width are you thinkin? Quote Link to comment
BlackBird620 Posted June 28, 2013 Author Report Share Posted June 28, 2013 Alright thanks for all the help do believe these rims and tires will work perfectly will post the photoshop'd pic as soon as I get to a computer Quote Link to comment
BlackBird620 Posted July 8, 2013 Author Report Share Posted July 8, 2013 ready to get these on once the ka swap is completed Quote Link to comment
