RedBanner Posted June 17, 2013 Report Share Posted June 17, 2013 Looking to get a tap made for shortining strut tubes. Dont much care for sectioning them. Can some one help me out with a thread pitch and size for 510 610 710 210 b210 or zx strut tube gland nuts? Not popping up in searches, worded a dozen ways and got nothing. 1 Quote Link to comment
H5WAGON Posted June 17, 2013 Report Share Posted June 17, 2013 Me and Derek were making calls on this...Tap was around $200ish This was just for that size range...not sure on specs. Also threaded area of tube is thinner than lower down where you would cut to section them. I'm sure tap would have no problem cutting it, just a FYI. B) Quote Link to comment
RedBanner Posted June 17, 2013 Author Report Share Posted June 17, 2013 Mine have sleeves. The last ones I did also where sleeved, some are not but the later ones are maybe. Or just some. And its not that far off, even if I had to ream the edge it would cut. Quote Link to comment
H5WAGON Posted June 17, 2013 Report Share Posted June 17, 2013 I was wanting to make more calls on this, but just opted to just cut and get it done. Threaded would be sweet, after tapping, just cut and clean up thread. For desired insert. You intentions to use stock perch or coil-overs? Coil-over cover all the scarring...lol Quote Link to comment
RedBanner Posted June 17, 2013 Author Report Share Posted June 17, 2013 I cut mine ground it smooth and used z car perches and springs, there not coil overs but there alot smaller diameter than most the others. 1 Quote Link to comment
RedBanner Posted June 17, 2013 Author Report Share Posted June 17, 2013 But im not wanting the cut and weld any more tubes. I fucked up twice and it took for ever last time. Quote Link to comment
H5WAGON Posted June 17, 2013 Report Share Posted June 17, 2013 Doing mine, we/he(Friend helping) cut to much, so my struts have swapped tops to fix the error we made. :geek: I was like great, hows this gona work out...lol 1 Quote Link to comment
RedBanner Posted June 17, 2013 Author Report Share Posted June 17, 2013 I.didnt.cut.enoughf, wanted the.gland nut as close to all the.way in as pissible Quote Link to comment
H5WAGON Posted June 17, 2013 Report Share Posted June 17, 2013 One of my inserts has a washer under it to fill tiny gap, but I'm not telling which one. :devil: 1 Quote Link to comment
RedBanner Posted June 17, 2013 Author Report Share Posted June 17, 2013 Lol, fuckit. Quote Link to comment
datzenmike Posted June 19, 2013 Report Share Posted June 19, 2013 Bjorn in Norway sent me these. Tapped an extra 20mm and cut off the extra so that zx inserts fit a European 810 tube. 1 Quote Link to comment
RedBanner Posted June 19, 2013 Author Report Share Posted June 19, 2013 Ive got several angles going on for a tap. Exactly what I was thinking. I search for his thread I heard mentioned .... Quote Link to comment
H5WAGON Posted June 19, 2013 Report Share Posted June 19, 2013 So whats the specs on that tap? Quote Link to comment
datzenmike Posted June 19, 2013 Report Share Posted June 19, 2013 M48 X 1.5 Forgot to post what was asked in the first place. 3 Quote Link to comment
thisismatt Posted June 19, 2013 Report Share Posted June 19, 2013 Ask Byron510 on the realm. He machines the thread back in. Did a set for me a few years ago... Yeah, mike is correct. Byron said it is M48x1.5 on the realm. Quote Link to comment
datzenmike Posted June 19, 2013 Report Share Posted June 19, 2013 My info was from Norway via the realm. Quote Link to comment
