bryant2482 Posted June 13, 2013 Report Share Posted June 13, 2013 they look like they will but i just want some experts who have done this before just to be safe Quote Link to comment
izzo Posted June 13, 2013 Report Share Posted June 13, 2013 they will fit, you will need to do a little fab work, though... The front tabs on the neon seats can bend flat. then you can install on the 720 seat rail welded to the floor. for the back two, you will probably need to make some spacers and make new holes in the floor. that's the easiest route. Quote Link to comment
bryant2482 Posted June 13, 2013 Author Report Share Posted June 13, 2013 ok cool sounds pretty simple. i figured i would have to bend the front tabs B) Quote Link to comment
wayno Posted June 13, 2013 Report Share Posted June 13, 2013 The "neon" seats bolted right into my 720, but they have you sitting a little higher than stock seat height, and I used washers on the rear brackets, as the rear mount holes are a bit large. Quote Link to comment
olskool720 Posted March 1, 2021 Report Share Posted March 1, 2021 On 6/13/2013 at 12:24 AM, wayno said: The "neon" seats bolted right into my 720, but they have you sitting a little higher than stock seat height, and I used washers on the rear brackets, as the rear mount holes are a bit large. Hi Wayno, I've seen your confirmation statements in various threads about Neon seats in 720s. Just confirming that they will work on all four holes for both seats. I snagged the wrong year Rodeo this past week, so need to take them back and my yard has several Neons. Can't get a refund, so will try an exchange. Thanks Bro. 1 Quote Link to comment
