Got my B210 GX
roadkill2525
  • Replies 124
Picked up a set of Appliance Wire Mag in 14x7, plan is to clean them up and sell.
                                   I've got three of those,but in 13".Might sell them.
  • 5 months later...
Cruising through Craigslst and found somebody parting out a '78 B210 GX, picked up a few parts from him for $200.
He still has the front sheet metal, bumpers and is planning on cutting out the rear quaters soon, still has some other parts if needed. Let me know so I can contact him if you're after anything.
What I got:
Front seats
Front seatbelts
Rear seatbelts
Tachometer
Steering column cover
Dome light cover
Clarion AM radio
Rear side windows
Pop-out windows
Complete doors, left and right
Hatch with glass
Huge score for $200!
What I got:
Front seats
Front seatbelts
Rear seatbelts
Tachometer
Dome light cover
Clarion AM radio
Rear side windows
Pop-out windows
Hatch with glass
Had the carburetor rebuilt by National Carb and replaced the PCV valve, getting everything back on and I can't find where the second in from the left goes.
Second from the left just goes to intake vacuum. Vacuum is used to work the Automatic Temperature Control valve in the snorkel to maintain a mix of warm and cold air (around 90 degrees) for the carburetor. A consistent 'warm' air temperature improves cold weather running and eliminated carb icing.
The car is running fine, decided to change the PCV valve and upon removing the old one it was packed with crud.
That crud is blow by vapors that have condensed. Does the engine get up to working temperature? About half way up the normal or warm range? Does the engine burn oil?
  • 6 months later...
New oil pump and oil pressure sending unit, had to cut a new gasket since the one that came with the pump was damaged but provided a good template. For all the good comes the bad with a broke hatch support bolt and glove box lid.
Finished replacing the oil pump and the battery was dead, replaced with a Braille B106 that weighs in at 6.9lbs. Had to replace the terminals and fix some wiring.
18618787_10210108813931627_1107827144_o1
  • 2 months later...
I've got a leak from a "heater hose" that does seem to be out of place. It runs along the the firewall behind the heater motor and ends with a cap (the point of the leak) but there's nothing shown in the Nissan service manual. I don't know if this was done by somebody else because the manual shows the cooling system stop at the engine side of the firewall and the heater control section has nothing on the hoses.
From heater core to engine (driver side)
20937666_10210883853187124_171485955_n.j
From engine to heater core (passenger side)
20904538_10210883852587109_1376080997_o.
Hose runs along firewall and ends with a cap.
20937698_10210883852307102_1674767243_n.
My b210gx is a 1978 hatchback and i bought another for spare parts. The only thing that I left was an empty shell and back seat. I took everything there was on car it was a complete car minus rear end
And how is this pertinent to my current problem?
That is supposed to be a prebent hose (braided) that ran behind the heater core then out. That seem to be a weak spot, I believe though it was from people pulling on the heater housing without removing all of the hoses properly.
  • 5 months later...
Very nice I have those on my watch list just haven't been able to pull the trigger yet.
I went through their website (http://www.datsun1200.asia/currency/USD), instead of using the eBay store and saved $90.
Might as well get it now so you know you've got it, I came by these purely by chance.
  • 1 month later...
Looking for the body gasket for the fuel filler and lines. Haven't had any luck finding one so far.
I've also have been looking at Techno Toy Tuning parts, I've seen that it uses 510 suspension parts but will the brake lines work as well?
28536417_10212335441555926_167151383_n.j
If you mean the stainless brake lines that replace your rubber lines, the fronts will. And I think one of the rears will match up to yours, you'll just have one left over.
  • 1 month later...
Starting to tear apart the front suspension and replacing stuff with Techno Toy Tuning parts. Removing a number of parts to clean and paint, hoping to get done before Datsloco.
31899349_10212783585039233_7719894391015
31956884_10212783590799377_8475188081056
31947838_10212783603199687_3709206943068
31924586_10212783860566121_8183160060461
31902157_10212783906287264_1774094137771
I've been thinking about doing some of these upgrades to my B210, I'd like to know how you like it when you're done.
