konig209 Posted December 12, 2015 Author Report Share Posted December 12, 2015 Uberkevin soon ill make a full writeup on everything needed with links info and all needed for the swap. Just got to make an adjustment to the rad brackets the guy made and should be set for sales to everyone. 1 Quote Link to comment
uberkevin Posted December 12, 2015 Report Share Posted December 12, 2015 Hell yeah thems are the type of things I like to hear.. idea on price? 1 Quote Link to comment
konig209 Posted December 12, 2015 Author Report Share Posted December 12, 2015 $320 plus shipping. Brass no aluminium b.s. 1 Quote Link to comment
datson4life Posted December 13, 2015 Report Share Posted December 13, 2015 They both have pros and cons to bting them to about same level http://www.cgj.com/2013/07/16/aluminum-vs-copper-brass-radiator-final-thoughts/ 1 Quote Link to comment
datson4life Posted December 13, 2015 Report Share Posted December 13, 2015 That one looks cool tho, i gotta checks its outs 1 Quote Link to comment
uberkevin Posted December 13, 2015 Report Share Posted December 13, 2015 They both have pros and cons to bting them to about same level http://www.cgj.com/2013/07/16/aluminum-vs-copper-brass-radiator-final-thoughts/ Cool little link... 320 is a bit much. 1 Quote Link to comment
konig209 Posted December 13, 2015 Author Report Share Posted December 13, 2015 Idk about the link lol. Brass short life is funny. Factory datsun is brass still good after 40 years 1 Quote Link to comment
uberkevin Posted December 13, 2015 Report Share Posted December 13, 2015 I'd want the brass color.. lol 2 Quote Link to comment
konig209 Posted December 14, 2015 Author Report Share Posted December 14, 2015 3 Quote Link to comment
konig209 Posted December 20, 2015 Author Report Share Posted December 20, 2015 Meh.....towing this thing around is starting to get expencive.... Sigh 1 Quote Link to comment
konig209 Posted December 26, 2015 Author Report Share Posted December 26, 2015 1 Quote Link to comment
mrbigtanker Posted December 26, 2015 Report Share Posted December 26, 2015 I like the ending it sounds like garbage cans got hit. Quote Link to comment
konig209 Posted December 27, 2015 Author Report Share Posted December 27, 2015 Yay i drove it. Quote Link to comment
finney Posted December 27, 2015 Report Share Posted December 27, 2015 how did it go and handle? Quote Link to comment
konig209 Posted December 27, 2015 Author Report Share Posted December 27, 2015 Didnt go so well. Ran out of gas. Was a lil too excited. The power is insane. Handle i still need to shave the bed a little more so the tire doesnt rub. It was just a rough cruise for me. But it felt amazing. Almost a year without driving it. My goal was reached before new years and well just felt good to drive it once again. Quote Link to comment
wayno Posted December 28, 2015 Report Share Posted December 28, 2015 For future reference, the 320 rearend housings/axles are 3 or 4 inches narrower, that way one can put wider tires on it and not have them sticking out or have to trim the rear fenders, especially when you 3 or 4 link it. But the axles are not as big, more like a car than a truck axle. 2 Quote Link to comment
konig209 Posted December 28, 2015 Author Report Share Posted December 28, 2015 Yes i know thanks wayno. But it would look funny with a narrow rear end and a wide front. All 4 wheels are x11 but thanks for the input. 2 Quote Link to comment
greenthumb Posted December 29, 2015 Report Share Posted December 29, 2015 What is your plan for an engine cooling fan? I can't see how I could run a puller fan(s) on mine without hacking the rad support to move the rad forward. Pusher fan is also an option I spose, but not as efficient as a puller, and again, more hacking required. What are the dimensions on that rad? 1 Quote Link to comment
konig209 Posted December 29, 2015 Author Report Share Posted December 29, 2015 Im going to borrow a friend flexalite slim fans. They are the thinnest set of fans. Only issue is they cost about $450 bucks. If that fails im going to run push and just say fuck it. As for dimentions. crossflow design. 3 row. 25" wide x 16" tall 1 Quote Link to comment
greenthumb Posted December 29, 2015 Report Share Posted December 29, 2015 thanks for the measurements. Keep us updated how you make out with those slimline fans. Did you cut the rad support to a widr opening to squeeze the rad in? 1 Quote Link to comment
mrbigtanker Posted December 30, 2015 Report Share Posted December 30, 2015 What is your plan for an engine cooling fan? I can't see how I could run a puller fan(s) on mine without hacking the rad support to move the rad forward. Pusher fan is also an option I spose, but not as efficient as a puller, and again, more hacking required. What are the dimensions on that rad? Pusher fan is not as efficient who told you that. I'm running a pusher fan on my truck and it does not get over 185 degrees period. At idle in the hot summer even. 1 Quote Link to comment
greenthumb Posted December 30, 2015 Report Share Posted December 30, 2015 trolling the all knowing interwebs I suppose. My son has twin small pushers on his KA 510, and his experience is the same as yours. Works fine. In the end, that will probably be the route I go as well. You remember the diameter of your pusher Ray? 2 Quote Link to comment
datson4life Posted December 30, 2015 Report Share Posted December 30, 2015 Pusher is the way to go on the 521. Maybe a 10-12 inch. Puller would involve 2 small diameter fans to clear the fan pulley on ka. Other than the hard suspension this truck is very fun. And this ka decided to act better in this truck. Bag it! 2 Quote Link to comment
mrbigtanker Posted December 30, 2015 Report Share Posted December 30, 2015 trolling the all knowing interwebs I suppose. My son has twin small pushers on his KA 510, and his experience is the same as yours. Works fine. In the end, that will probably be the route I go as well. You remember the diameter of your pusher Ray? I think it's a 12". I cut the front nice and clean and pulled the support out and boom baby in business. Plus it's so much cleaner to looking in to the engine bay. It helps with what I got under my hood,lord knows I need all the help. 1 Quote Link to comment
mrbigtanker Posted December 30, 2015 Report Share Posted December 30, 2015 Pusher is the way to go on the 521. Maybe a 10-12 inch. Puller would involve 2 small diameter fans to clear the fan pulley on ka. Other than the hard suspension this truck is very fun. And this ka decided to act better in this truck. Bag it! Not just a KA FJ L the pulley comes to close to the center line of the radiator. 1 Quote Link to comment
