---- Copper 280zx turbo ----
I'm BLUE
The turbo it's self is a T3/TO4E so T3 rebuild kit should work, if you wanna save time take it to a turbo rebuilt shop I would ask what the proper rebuild kit it needs If I have time this week I can go to a turbo shop close to my work and ask they rebuild nothing but turbos. These turbos are a little rare to find. If you were to find a turbo of that size of today's turbos it would run you probably close to $800-$1000 give it a try if all fails then find a stock zxt T3 turbo.
  • Replies 97
Thankyou I appreciate that Arche ! I don't want to put another member into a bind on my behalf either :)
there is a shop on scappoose that rebuilds turbos you could go talk to them . i cant remember the name
Thankyou DISLEXIC ! That seems like a sensible solution as well.
I just barely looked that up and emailed him this early AM ( I believe ? ).
He replied back = " my base rate is typically $400 "
 I do need to just bring it in and talk to them like you said.
600hp? DTP you got a winner! These old school aftermarket parts are really neat. If you find an old school supercharger I call dibs! :P
No kidding huh :blink: ? :lol:
They are too neat...
hahah :lol: I'll keep ya in mind if I do Kirden ;)
  • 4 months later...
I've been either occupied or unable to work on my stuff for a bit.
Nice to be able to now and again :)
pop off the valve cover.
L28ET copper inspection 2882 by 71240z, on Flickr
set at TDC and pushed timing chain wedge down snug.
L28ET copper inspection 2903 by 71240z, on Flickr
L28ET copper inspection 2906 by 71240z, on Flickr
zipped out the 19mm bolt ... remove gear ...  and promptly screwed it back in to keep it in it's place.
L28ET copper inspection 2902 by 71240z, on Flickr
yanked turbo and manifolds as a unit .. since I can and gaskets are like 1yr old.
L28ET copper inspection 2896 by 71240z, on Flickr
Cylinders look pretty good.
L28ET copper inspection 2901 by 71240z, on Flickr
L28ET copper inspection 2895 by 71240z, on Flickr
I have the turbo separated off the manifold , but am away from my sanctuary , so will have to get pics another time.
Turbo will be re-built.
Turbo Dis-assembly.
Started with something close to this , but had already pulled the cotter key and actuator off. ( as well as some bolts ).
Copper Stuff 11 11 13 110 by 71240z, on Flickr
Compressor housing is on the <--- left (aluminum) ... turbine housing is on the right ----> .... CHRA is in the center of it all :)
Split it all apart ... there were 2 broken bolts in the turbine housing already , and I slightly rounded one bolt head .. that was in a hard to reach place (only could get an open ended wrench in there...) after about 5-10 minutes or more I popped it loose .. was happy :)
Copper Stuff 11 11 13 109 by 71240z, on Flickr
Copper Stuff 11 11 13 108 by 71240z, on Flickr
CHRA
Copper Stuff 11 11 13 107 by 71240z, on Flickr
Compressor wheel + 7/16" nut.
Copper Stuff 11 11 13 106 by 71240z, on Flickr
Turbine wheel.
Copper Stuff 11 11 13 105 by 71240z, on Flickr
Copper Stuff 11 11 13 104 by 71240z, on Flickr
Copper Stuff 11 11 13 103 by 71240z, on Flickr
Exhaust down-pipe.. at the turbo-housing.
Copper Stuff 11 11 13 101 by 71240z, on Flickr
Down-pipe ... exhaust pipe side (hookup below)
Copper Stuff 11 11 13 099 by 71240z, on Flickr
7/16" inch wrench/socket size on this puppy.
Copper Stuff 11 11 13 098 by 71240z, on Flickr
Popped loose ... carefully ;)
Copper Stuff 11 11 13 095 by 71240z, on Flickr
Actuator housing. Say's Nissan right on it. I don't know how well it does or doesn't work unfortunately :) .
Copper Stuff 11 11 13 097 by 71240z, on Flickr
Copper Stuff 11 11 13 096 by 71240z, on Flickr
This is  part of the CHRA (less compressor wheel + thrust washer + retainer and compressor backing plate ? haha)
You can see the journal bearing in the center ( it is held in by a snap ring on each side to keep it in place.. oil floating :) ).
Remember you're looking at the compressor side (cool side).
Copper Stuff 11 11 13 040 by 71240z, on Flickr
Pulling off compressor wheel
Copper Stuff 11 11 13 094 by 71240z, on Flickr
Another view of the down-pipe.
On the right is where it literally hooks to the exhaust pipe (if you weren't famaliar :) )
On the left is where is connects to the turbo housing :D
Copper Stuff 11 11 13 093 by 71240z, on Flickr
This is the thrust bearing .. and the dynamic seal floats inside it (has another tiny "piston ring looking" compressor seal on it). Thrust bearing looks like a "butterfly" in my fingers :)
NOTE: --- this not the only sole bearing if you arn't aware already :)
Copper Stuff 11 11 13 092 by 71240z, on Flickr
At the top is the oil "feed" (with the white tape wrapped around) I choose to take out the banjo fitting instead of the 2 12mm bolts.
At the bottom is the oil "return" port.
You are looking at the compressor side ... facing yourself ... where the thrust bearing/retainer/compressor housing plate etc all assemble on.
In the center are a couple of snap rings holding the journal bearings.
There are (2) journal bearings on this model.
Copper Stuff 11 11 13 090 by 71240z, on Flickr
After using snap-ring pliers to pull (1) snap-ring out of the compressor side.
The journal bearing slid right out.
Copper Stuff 11 11 13 089 by 71240z, on Flickr
A closer look at the thrust bearing and dynamic seal.
NOTE: The thrust bearing locates on (2) roll pins in the housing , and it has oiling grooves that are to pointed inwards <--- when assemblying :)
Copper Stuff 11 11 13 088 by 71240z, on Flickr
Oil inlet taped up.
Copper Stuff 11 11 13 087 by 71240z, on Flickr
Another look at the housing.
Oil outlet is pictured.
Compressor side is facing ^^^ up.
Turbine side is facing down.
I'll be taking the oil flange bolts out when it's time for cleaning ...
Copper Stuff 11 11 13 086 by 71240z, on Flickr
Turbine side shield ? I'm not sure of the entire purpose at this moment , but will look later.
it goes on the turbine shaft over the seals it looks like.
Copper Stuff 11 11 13 085 by 71240z, on Flickr
Turbine side journal bearing and snap-ring.
NOTE: journal bearings have oil holes drilled in them for lubrication  8-) (if you weren't already aware).
Copper Stuff 11 11 13 054 by 71240z, on Flickr
Opps forgot to mention ... I marked the assemblys and what not the best I could before dis-assembly.
All I can do for this very moment.
turbine side journal bearing and snap-ring.
Yeah I think it needs to be replaced :)
Copper Stuff 11 11 13 084 by 71240z, on Flickr
The shaft.
Turbine wheel to the left.
The surfaces look pretty good really (although this is my first turbo ... lol)
Copper Stuff 11 11 13 083 by 71240z, on Flickr
One of the seals is obliterated ... lol ... look at the front seal (direction of the threaded shaft).
A closer look ... I know it's hard to see ... you're looking at seals that look like "small piston rings" ;)
The rear seal (towards the turbine) looked "ok" , but that's just me looking at it. Yeah not a good test lol.
Copper Stuff 11 11 13 082 by 71240z, on Flickr
Copper Stuff 11 11 13 081 by 71240z, on Flickr
You can see in this picture the "gold plated" looking rings around the bolts.
These rings are also split ... not one continous unit :)
Those keep everything clamped together(or from walking if you will to describe ?) as we all know.
Copper Stuff 11 11 13 080 by 71240z, on Flickr
Like so...
Copper Stuff 11 11 13 078 by 71240z, on Flickr
Copper Stuff 11 11 13 077 by 71240z, on Flickr
Copper Stuff 11 11 13 076 by 71240z, on Flickr
I kept spinning the turbines/shaft while taking it apart carefully to make it wasn't contact much if at all.
minimal , but did a touch on the inside myself ... *roll eyes*
Copper Stuff 11 11 13 075 by 71240z, on Flickr
Copper Stuff 11 11 13 074 by 71240z, on Flickr
Been cleaning the turbo parts as I go along... I'm trying to get the stuff as clean as am reasonably able to.
Center Housing .. part of the "CHRA" ... ( viewed from the compressor side)
11 13 13 turbo cleaning 006 by 71240z, on Flickr
You can see the (2) internal snap-rings that hold the (2) journal bearings in the housing. As soon as they are installed then (1) more snap ring on the outside of each journal bearing is fitted externally to hold them in place. Wear looks normal.
11 13 13 turbo cleaning 007 by 71240z, on Flickr
11 13 13 turbo cleaning 008 by 71240z, on Flickr
Oil "feed" pressure inlet... no adaptor in picture.
11 13 13 turbo cleaning 009 by 71240z, on Flickr
Oil "return" outlet .. no adaptor in picture.
11 13 13 turbo cleaning 010 by 71240z, on Flickr
angle picture taken from the compressor side of the Center Housing.
11 13 13 turbo cleaning 011 by 71240z, on Flickr
Opps ... see the o-ring laying on the CHRA (Center Housing ) ... it seals against the compressor backing plate.
11 13 13 turbo cleaning 012 by 71240z, on Flickr
Oil "feed" pressure side ... inlet adapter flange ... utilizing a banjo bolt + (2) copper washers to compete it.
11 13 13 turbo cleaning 013 by 71240z, on Flickr
Still in the process of re-cleaning all of this stuff before using.
Cleaned the compressor housing. Paint is on there pretty good so either chemicals or bead blasting... or just leave it :)
11 13 13 turbo cleaning 014 by 71240z, on Flickr
11 13 13 turbo cleaning 015 by 71240z, on Flickr
Cleaned the turbine housing. 2-broken bolts arn't that deep , heat is available , and shouldn't be hard to get out.
11 13 13 turbo cleaning 016 by 71240z, on Flickr
a few surface superficial marks from removal. I attempted to be as careful as possible. Turbine looks good.
11 13 13 turbo cleaning 017 by 71240z, on Flickr
11 13 13 turbo cleaning 018 by 71240z, on Flickr
I have no reason to pull this apart. Waste gate is very free and clean/clear. If need be I'll heat it up carefully and pull the bolts out. Penetration fluid first of course before doing so.
11 13 13 turbo cleaning 019 by 71240z, on Flickr
11 13 13 turbo cleaning 020 by 71240z, on Flickr
Compressor backing plate cleaned.
11 13 13 turbo cleaning 021 by 71240z, on Flickr
The center around the hole is where the dynamic seal rides against.
11 13 13 turbo cleaning 022 by 71240z, on Flickr
Other side of the compressor backing plate. It looks dirty , but it is nearly.. clean. A lot of that stuff is baked in or something.
11 13 13 turbo cleaning 023 by 71240z, on Flickr
Inside the center of the compressor backing plate is where the dynamic "piston ring seal" (it's the type) locks in and rides.
The wears looks normal and nothing alarming.
NOTE: it looks like there is a "chip" off the edge of the center , but it is casted in.. so not a chip :)
11 13 13 turbo cleaning 024 by 71240z, on Flickr
11 13 13 turbo cleaning 025 by 71240z, on Flickr
11 13 13 turbo cleaning 026 by 71240z, on Flickr
Compressor housing outlet had this stamped/casted in.. never noticed it until I started to clean it lol.
11 13 13 turbo cleaning 027 by 71240z, on Flickr
Center housing markings from the turbine side.
11 13 13 turbo cleaning 028 by 71240z, on Flickr
11 13 13 turbo cleaning 029 by 71240z, on Flickr
11 13 13 turbo cleaning 030 by 71240z, on Flickr
11 13 13 turbo cleaning 031 by 71240z, on Flickr
NOTE: I have not... cleaned anything on this shaft yet until I figure out what is safe to do so with. Will be looking tonight
Turbine wheel on the left ... compressor wheel on the right ... (2) journal bearings on the shaft (gold looking) .... just to the left of the compressor wheel is the "dynamic seal" that locks in the the thrust bearing. This is considered to be a "hybrid turbo" by rebuilder's and parts suppliers from what I have been told/understand. Their words not mine :) lol .
Turbo Cleaning 11 13 13 turbine shaft pics 001 by 71240z, on Flickr
I'm looking at using a "staggered/step-gap" turbine side compressor seal since it looks like a superior design as opposed to a "butt-joint" . I'll be doing more research before executing though.
Turbo Cleaning 11 13 13 turbine shaft pics 002 by 71240z, on Flickr
From the left: Compressor side journal bearing ---> Thrust bearing ----> Dynamic seal ----> compressor wheel. Many of the T3/T4's-ish ... from what I understand use the 4-piece carbon seals as opposed to the Dynamic seal. I'm glad I pulled my turbo apart before ordered to be 100% sure.
Turbo Cleaning 11 13 13 turbine shaft pics 003 by 71240z, on Flickr
You can see oil transfer grooves blue-printed into the thrust-bearing. Look at all those oiling holes on the rest of the components.
Turbo Cleaning 11 13 13 turbine shaft pics 004 by 71240z, on Flickr
Turbo Cleaning 11 13 13 turbine shaft pics 005 by 71240z, on Flickr
Turbo Cleaning 11 13 13 turbine shaft pics 006 by 71240z, on Flickr
That's it for this update.
BLUE
That's great that you found a rebuild kit takes time things are coming along.
Thanks Arche ! yeah it does take time. I had to email , call , etc 5-6 places , and none of them had a clue which kit I needed.
So it's satisfying that at least it's moving along and might get done :lol: :D
Oil inlet/outlet gaskets. Compressor backing plate seal/o-ring (black). , and what looks to be a housing seal/o-ring ? I'm not sure will have to measure the size against mine.
Shaft nut (compressor side)
Thrust collar that houses the dynamic front compressor side seal (piston ring type).
Turbine shaft seal (bigger one) , and compressor side seal (standard butt joint "piston ring" type) I'll be using the updated compressor seal in replacement of this one pictured during the rebuild.
Journal bearings... they are held in by snap rings.
270-degree bronze Thrust bearing (funny looking gold thing) , turbine housing bolts , backing plate bolts , brackets , locking brackets , exhaust studs(black) , snap rings , and that's pretty close to it .... I think haha.
Doing a "little" work.. ( lol just a little ).
Decided to start drilling out the broken bolt.
The other broken bolt I shall slip a nut over the top .. weld it onto the existing snapped bolt protruding surface and wrench the effer out.
Left hand drill bits ( and right hand drill bits..)
3/32nd LHD drill bit seemed to be doing a fair job.
Explanation needed ? if drilling lots (or even a little) there should be lubricant involved :) .
Filled cavity with rapid-tap and wen't to work.
a bit off center lol , but should be fine
It's practically drilled through as this point , but no pictures.
Have to go pick up another bit or two since I was kinda stupidly tired  + snapped the bit  :shock:  :lol:
That's all for nowz ...
