Daryl Posted July 15, 2020 Report Share Posted July 15, 2020 Got a 521 the sec I seen er. O the joy of pre-smog! 5 Quote Link to comment
Fetch Posted July 22, 2020 Report Share Posted July 22, 2020 Clean A10 goon, engine looks molested but, 30 mpg. https://spokane.craigslist.org/cto/d/chewelah-1981-datsun-510-station-wagon/7163663610.html Quote Link to comment
carterb Posted August 1, 2020 Report Share Posted August 1, 2020 1971 Datsun 510 4dr $10,000 to open https://www.ebay.com/itm/1971-Datsun-sedan/224101306414?hash=item342d7a902e:g:zAwAAOSwBJpfJIHt Since I've owned the car (May 2012), this is what I've done to it: 1) Rebuilt front end (ball joints, inner and outer tie rods, idler arm, all but the center link, but I have that part to include) 2) Rebuilt front calipers, new pads, rotors did not need turning, still nice and thick. Replaced bearings and seals. Also, rebuilt rear drum brake calipers and shoes, springs. New master brake cylinder installed. 3) Rebuilt front suspension with new stock type McPherson front struts and Nismo springs (Nissan performance division). Rear suspension rebuilt with inflatable shocks and D50 springs. 4) New stock fuel pump, new dual fuel lines and linkages leading to dual SU carbs. Fabricated air cleaner made by Mr Marshall (local 510 guru). All works very well. Periodically add Marvel Mystery Oil into top of the SUs. 5) Installed 5-speed tranny from 1981 Nissan pick-up, rebuilt by Marshall. Shortened drive shaft, new U-joints and rear tranny seal. New clutch on that 5-speed while I had it out. 6) New exhaust system by Nathan Marshall. Special extended 2 into 1 hand-made header, new resonator and muffler. 7) New Futofab anti-sway bar in front and rear. 😎 New Kumho tires on 70s era turbine mags, originally for 240Z cars (I'm told...from Marshall's parts pile). Stock wheels, hubcaps and new Kumho tires come with the car in case you want to go stock (see picture). Tires have been stored in the dark, filled with nitrogen, good as new. 9) Interior essentially unchanged post restoration. Going to 5-speed, the shifter moved rear about 3-4" and I had to cut the carpet. Typical cracks in the dashboard. 10) Trunk in good shape. Lid has a crack in the paint (see picture). Looks like body putty may have been used here at some point? 11) Body has some "cancer" (rust bubbles) here and there which I've tried to photograph. The underside is still in excellent shape. Overall, the body and paint have held up well. 12) New chrome rear bumper from Futofab, look like stock only better (thicker and no center seam, which always rusts). 13) New front and rear OEM window gaskets installed. Front has a chrome insert that I could not get in, but obviously it comes with it…maybe buyer can? Obviously, odometer is what it is...who knows? Included is a fresh L16 rebuilt engine. The present engine is strong and doesn't use oil. I just had an extra sitting in my crawlspace and thought I'd throw it into the deal to help sell the car. It's an excellent rebuild job. Also included, you can see the rear panel has cracking. I'm including a Futofab rear panel in case the buyer wants to replace this panel sooner or later. This has been an excellent car. Everywhere you go in this car, people will wave at you, smile at you, want to talk to you, tell you about the Datsun they had or their mother had. I'm getting over the hill to continue crawling around under it. Thanks for your interest. 1 Quote Link to comment
carterb Posted August 1, 2020 Report Share Posted August 1, 2020 1972 Datsun 510 2dr $8,999 to open https://www.ebay.com/itm/1972-Datsun-Other/264813069149?hash=item3da816c35d:g:MA8AAOSwbVJfIf1u Up for sale is a Datsun 510 that I have owned on and off over the years. Got this car in 2005 from an older man that had not driven the car since the late 80's. Car was originally painted a green color from the factory but was painted white at some point. Cleaned out gas tank and put new rubber fuel hoses and fuel filler neck hose on. Rebuilt brake and clutch master cylinder, clutch slave and replaced rear drum wheel cylinders and got brakes working. Car has Weber 2 barrel downdraft carburetor L16 motor, manual transmission and aluminum wheels. Front driver floor pan has a "For Sale" sign installed by previous owner covering hole. Passenger floor pan has some rust holes and will need to be replaced as well as the drivers if it is to look original. Rear seat floor pans are in good shape, a little rust around the body plugs. Spare tire well was rusted out and has had a patch welded in by previous owner, see pic. Left and right rear quarters have some damage, see pics. Hood had rust around the latch and had hood pins put in. Frame of car is in great shape. Rear seat cover separating at the seams. Got everything working on the car and was daily driven occasionally over a couple of years. Tried to keep car as original as possible and use factory parts. I Sold the car in 2008 and bought it back in 2011 from different person. Car was still running but rear differential had a cracked spider gear and will need fixing before driving. I put the car into storage and have not had time to work on the car since then. Quote Link to comment
grannyknot Posted August 1, 2020 Report Share Posted August 1, 2020 @carterb, interesting that you put those last two 510's next to each other, the first mustard 510 looks like a gem with only a few issues at $10k whereas the second white 510 is a disaster at the low low price of $9k 1 Quote Link to comment
thisismatt Posted August 1, 2020 Report Share Posted August 1, 2020 24 minutes ago, grannyknot said: @carterb, interesting that you put those last two 510's next to each other, the first mustard 510 looks like a gem with only a few issues at $10k whereas the second white 510 is a disaster at the low low price of $9k Did you look closely at the mustard? Lots of cancer and bad body work. It's also a 4 dr compared to the 2 dr. 2 Quote Link to comment
KoHeartsGPA Posted August 2, 2020 Report Share Posted August 2, 2020 Yeah there are trade offs with those two, pic your dime 🥰 Quote Link to comment
BrothersGarage Posted August 5, 2020 Report Share Posted August 5, 2020 (edited) 1974 and 75 Datsun 620 trucks - $900https://offerup.com/item/detail/924602228/?_branch_match_id=686048347037455512 1971 Datsun 521 Pickup - $3500https://spokane.craigslist.org/cto/d/careywood-1971-datsun-521-pickup/7169950754.html 1969 Datsun Roadster - $14500https://seattle.craigslist.org/see/cto/d/langley-1969-datsun-roadster/7171135157.html Edited August 5, 2020 by BrothersGarage 1 Quote Link to comment
carterb Posted August 7, 2020 Report Share Posted August 7, 2020 1972 Datsun 510 2dr https://www.ebay.com/itm/1972-Datsun-510-/264819717249?_trksid=p2385738.m4383.l4275.c10 Bidding currently at $7,400 About this vehicle This is a 1972 Datsun 510 coupe very clean with no rust. Car was resprayed blue a while back but the paint is really really nice just has some chips here and there no dings or dents. Could be perfect with some touch ups or a perfect base to build any way you like! I've owned the car for a few years now and it's just been sitting in storage. Car fires right up and drives good. Just haven't got around to building this car yet and still have too many projects. Would love to hopefully pass it on to someone that will drive it and give it the attention I can't. Mileage shows a little over 13k but I have not been able to verify that or if the odometer is working. I have a clear California title from 1990 when it was last registered. Seller's Notes Walk around video: https://vimeo.com/444754071 1 Quote Link to comment
carterb Posted August 10, 2020 Report Share Posted August 10, 2020 On 8/1/2020 at 10:31 AM, carterb said: 1971 Datsun 510 4dr $10,000 to open https://www.ebay.com/itm/1971-Datsun-sedan/224101306414?hash=item342d7a902e:g:zAwAAOSwBJpfJIHt Since I've owned the car (May 2012), this is what I've done to it: 1) Rebuilt front end (ball joints, inner and outer tie rods, idler arm, all but the center link, but I have that part to include) 2) Rebuilt front calipers, new pads, rotors did not need turning, still nice and thick. Replaced bearings and seals. Also, rebuilt rear drum brake calipers and shoes, springs. New master brake cylinder installed. 3) Rebuilt front suspension with new stock type McPherson front struts and Nismo springs (Nissan performance division). Rear suspension rebuilt with inflatable shocks and D50 springs. 4) New stock fuel pump, new dual fuel lines and linkages leading to dual SU carbs. Fabricated air cleaner made by Mr Marshall (local 510 guru). All works very well. Periodically add Marvel Mystery Oil into top of the SUs. 5) Installed 5-speed tranny from 1981 Nissan pick-up, rebuilt by Marshall. Shortened drive shaft, new U-joints and rear tranny seal. New clutch on that 5-speed while I had it out. 6) New exhaust system by Nathan Marshall. Special extended 2 into 1 hand-made header, new resonator and muffler. 7) New Futofab anti-sway bar in front and rear. 😎 New Kumho tires on 70s era turbine mags, originally for 240Z cars (I'm told...from Marshall's parts pile). Stock wheels, hubcaps and new Kumho tires come with the car in case you want to go stock (see picture). Tires have been stored in the dark, filled with nitrogen, good as new. 9) Interior essentially unchanged post restoration. Going to 5-speed, the shifter moved rear about 3-4" and I had to cut the carpet. Typical cracks in the dashboard. 10) Trunk in good shape. Lid has a crack in the paint (see picture). Looks like body putty may have been used here at some point? 11) Body has some "cancer" (rust bubbles) here and there which I've tried to photograph. The underside is still in excellent shape. Overall, the body and paint have held up well. 12) New chrome rear bumper from Futofab, look like stock only better (thicker and no center seam, which always rusts). 13) New front and rear OEM window gaskets installed. Front has a chrome insert that I could not get in, but obviously it comes with it…maybe buyer can? Obviously, odometer is what it is...who knows? Included is a fresh L16 rebuilt engine. The present engine is strong and doesn't use oil. I just had an extra sitting in my crawlspace and thought I'd throw it into the deal to help sell the car. It's an excellent rebuild job. Also included, you can see the rear panel has cracking. I'm including a Futofab rear panel in case the buyer wants to replace this panel sooner or later. This has been an excellent car. Everywhere you go in this car, people will wave at you, smile at you, want to talk to you, tell you about the Datsun they had or their mother had. I'm getting over the hill to continue crawling around under it. Thanks for your interest. Bid to $10,400 Did not meet reserve. Seems like a healthy enough price but BIN was $15,000 1 Quote Link to comment
carterb Posted August 11, 2020 Report Share Posted August 11, 2020 1972 cactus green VG30 4dr 510 on BAT https://bringatrailer.com/listing/1972-datsun-510-4-door-sedan-8/ Quote Link to comment
carterb Posted August 17, 2020 Report Share Posted August 17, 2020 1973 Datsun 510 2dr on BAT https://bringatrailer.com/listing/1973-datsun-510-2/ Quote Link to comment
carterb Posted August 18, 2020 Report Share Posted August 18, 2020 On 8/11/2020 at 11:43 AM, carterb said: 1972 cactus green VG30 4dr 510 on BAT https://bringatrailer.com/listing/1972-datsun-510-4-door-sedan-8/ Sold For $31,000 On 8/18/20 Quote Link to comment
carterb Posted August 18, 2020 Report Share Posted August 18, 2020 1970 Datsun 510 on The Driven Exchange https://www.thedrivenexchange.com/product/1970-datsun-510-resto-mod/ 1 Quote Link to comment
B^2 Posted August 19, 2020 Report Share Posted August 19, 2020 On 8/5/2020 at 12:01 PM, BrothersGarage said: 1974 and 75 Datsun 620 trucks - $900https://offerup.com/item/detail/924602228/?_branch_match_id=686048347037455512 1971 Datsun 521 Pickup - $3500https://spokane.craigslist.org/cto/d/careywood-1971-datsun-521-pickup/7169950754.html 1969 Datsun Roadster - $14500https://seattle.craigslist.org/see/cto/d/langley-1969-datsun-roadster/7171135157.html I wonder how that blue 521 would look if you washed it. I wish there were more pictures. 1 Quote Link to comment
carterb Posted August 19, 2020 Report Share Posted August 19, 2020 23 hours ago, carterb said: 1970 Datsun 510 on The Driven Exchange https://www.thedrivenexchange.com/product/1970-datsun-510-resto-mod/ Sold for: $22,500 Quote Link to comment
carterb Posted August 22, 2020 Report Share Posted August 22, 2020 1971 Datsun 510 wagon $4,800 https://seattle.craigslist.org/est/cto/d/snoqualmie-1971-datsun-510-wagon/7182289526.html 1 Quote Link to comment
carterb Posted August 25, 2020 Report Share Posted August 25, 2020 On 8/17/2020 at 12:24 PM, carterb said: 1973 Datsun 510 2dr on BAT https://bringatrailer.com/listing/1973-datsun-510-2/ Bid To $25,500 On 8/24/20 Quote Link to comment
BrothersGarage Posted August 26, 2020 Report Share Posted August 26, 2020 1967 Datsun PL 411 - $5000https://seattle.craigslist.org/see/cto/d/everett-1967-datsun-pl-411/7184405612.html Quote Link to comment
angliagt Posted August 26, 2020 Report Share Posted August 26, 2020 FREE! - Three 720's.http://humboldt.craigslist.org/pts/d/zenia-free-1984-nissan-pickups/7184586028.html In Zenia,CA. 1 Quote Link to comment
carterb Posted August 29, 2020 Report Share Posted August 29, 2020 1971 Datsun 510 2dr on BAT https://bringatrailer.com/listing/1971-datsun-510-36/ 2 Quote Link to comment
BrothersGarage Posted August 31, 2020 Report Share Posted August 31, 2020 1976 Datsun 620 truck - $7,000https://seattle.craigslist.org/sno/cto/d/snohomish-1976-datsun-620-truck/7186853687.html Quote Link to comment
BrothersGarage Posted September 1, 2020 Report Share Posted September 1, 2020 (edited) 1970 521 - $500 - No engine or trans, but he has them available if you want them as wellhttps://portland.craigslist.org/mlt/cto/d/portland-project-1970-datsun-521/7187696387.html Edited September 1, 2020 by BrothersGarage Quote Link to comment
bastardo Posted September 1, 2020 Report Share Posted September 1, 2020 10 minutes ago, BrothersGarage said: 1970 521 - $500 - No engine or trans, but he has them available if you want them as well Where, no link? Quote Link to comment
BrothersGarage Posted September 1, 2020 Report Share Posted September 1, 2020 1 minute ago, bastardo said: Where, no link? https://portland.craigslist.org/mlt/cto/d/portland-project-1970-datsun-521/7187696387.html 1 Quote Link to comment
