510farmer Posted May 19, 2013 Report Share Posted May 19, 2013 hello guys im looking for some info on how to adjust the hood the rite way on my 510 this is what i have going on, as you see the difference, i would like it to sit level any help or a link? thx farmer Quote Link to comment
john510 Posted May 19, 2013 Report Share Posted May 19, 2013 Ya know my cars hood and trim sit just like yours.If i try to level out the hood trim with the eyebrow moulding the hood sits higher than the fender.Theres also a little bit of difference front to back.My car has never been wrecked.Im thinking thats how its supposed to look.You can adjust your hood heighth at the hood latch.Loosen the big nut and then you can turn the screw.It will change how far down the hood sits. Quote Link to comment
510farmer Posted May 20, 2013 Author Report Share Posted May 20, 2013 hey thx john thats what i did rite after i posted that i went back out there and figured it out and yes i do think maybe they do sit like that for 1 after doing the above mentioned adjustment it would sit level but the hood release would not release the catch and 2 the side of the hood would sit higher than the fender so i found a happy medium but now i noticed that when its idling the hood looks like its rocking back a forth almost like it needs hood bumpers under the far corners well here is a pic of my happy medium and thx again john my name is john also thx farmer Quote Link to comment
DanielC Posted May 20, 2013 Report Share Posted May 20, 2013 I do not know about 510 hoods, but 521 hoods rest on some rubber bumpers that hold the hood at the right height. The hood catch pulls the hood down on the bumpers, enough to prevent the hood from wobbling, or fluttering in the wind. 1 Quote Link to comment
Ranman72 Posted May 20, 2013 Report Share Posted May 20, 2013 on some of the later 510 I have seen a nut in the core support that you can put a threaded rubber bumper in and adjust side to side height not sure what years had them but my 72 did and my 68 dosnt Quote Link to comment
q-tip Posted May 20, 2013 Report Share Posted May 20, 2013 The 510's have two rubber bumpers on each side one in the front and one in the back, the front one is thicker than the rear one Quote Link to comment
hang_510 Posted May 23, 2013 Report Share Posted May 23, 2013 but now i noticed that when its idling the hood looks like its rocking back a forth The 510's have two rubber bumpers on each side one in the front and one in the back, the front one is thicker than the rear one i added a 1/4" thick strip of rubber on top of the bumpers and have it adjusted against it. aligned nicely and no vibrations at any speed. Quote Link to comment
SandyMush620 Posted May 24, 2013 Report Share Posted May 24, 2013 Hey farmer, based on the pics, it looks like your hood was low but is also a bit too far forward. Not familiar with the 510 hood specifically, but most hoods can be loosened at the hinges and adjusted front to back slightly. It looks like sliding it back a little would line it up well. Quote Link to comment
MikeRL411 Posted May 29, 2013 Report Share Posted May 29, 2013 521 hood "bumpers" install in holes on the fender to engine compartment flange. They are oversized for most other uses, fortunately! A few judicous cuts with a razor blade or utility knife will allow installation and eliminate side to side vibration and provide enough elevation that just may be what you need to align the front fascia. Quote Link to comment
