Frenched Clearance Lights on 620, 710, 280zx and other datsuns
sick620
What you will need:
   Screwdriver
  8 Bolts that are slightly longer than the originals with 8 matching nuts and 8 washers of your choice.
   Knife
Step one:
  Unhook the 2 wires hooked to clearance light
Step two:
  Remove 2 screws shown here
Step three:
 Remove assembly from panel
 Remove metal clips shown and discard
 Discard metal ring shown
Step four:
On a 620, and possibly other models you cant keep the rubber surrounding on the back lights without cutting it or removing it becasue it gets in the way. So if doing this mod on a 620 I suggest just removing the black cover from the light housing.
there are multiple ways of doing this, and the way I will show you is just the option a personally use.
cut around this rubber piece, then pull the rubber off the light body and pull the chord thru and remove the rubber entirely.
you will be left with this
Forget this step if working on front fender lights, the rubber can be left on.
Step five:
Place lens on metal housing and set the whole assembly behind the body panel.
Run screws with washers through holes.
Secure with nuts from behind,
 repeat steps for all 4 lights on vehicle....
Don't forget to plug them all back in when your done
Finished product
  • Replies 12
From this????
To that???
Maybe if the exterior was fitted with some thin black trim and or to cover those bolts and 'indentations' in the metal
im pretty sure a wash and buff will take care of that line and dirt pretty nicely...
  • 1 year later...
you could probably use a bolt with a domed head that has no slot in order to get those screws looking smoother. they have them where theres a square  protrusion just above the threads to keep them from rotating, kinda like a small carriage bolt?
I like the flush clearance lights but removing them is illegal and unsafe. Their whole point is to make the vehicle visible to others in the dark and to tell front from back. Don't complain if someone T bones your truck while it's parked overnight.
