My First 72 620 (Dirt)
DatDoug
Just picked up this 72 620 from a tree farm in Shelton.  Its all stock except for the 15" chevy steelies in the back & someone already put in a matchbox dizzy B)
Its got surface rust here & there, some dings & dents.  Has the stock L16 & 4 speed trans.  It started right up but wouldn't idle.  It would not go into gear either.
Loaded her up & brought her home for some TLC.
  • Replies 17
I figured out the running issue.  There was a huge hole in the brake booster vacuum line.  I also drained the gas tank of its brownish fuel.  I put on a weber & it now runs like a top!  Changed the oil & put in some fresh NGK spark plugs.  Drained the coolant, flushed the radiator & put in some fresh coolant.  The slave was shot so I put on a new one & after a good bleeding it now shifts.  Surprisingly the brakes are good!
Now its time for some pics before I clean her up.
Doug.
Curious as what your method and what you use to polish these things up is...  What kind of compound, buffing etc?
I use TR-3 Cleaner Wax.  This stuff is AWESOME!  Just rub it on by hand & dry off with clean cloth.  It wont get that deep shine that a mechanical buffer will but its quicker & easier.  The last can I bought was @ O'reillys.
  • 3 weeks later...
After countless hours of Knuckle-Busting work on the 72, it is now my D.D.D. B)
5 speed trans swap
lowered
new radiator
white walls
clear-coated rusty stock rims
weber
stereo
L8r model seat belts
front bumper
buffed paint
Clutch slave
oil,temp & volt gauges
& more!
She runs & drives good.  Needs new valve guides cuz she smokes in the morning bad.  Needs front suspension work.  Shakes bad @ 50 mph.
Here are PICS as it sits now.
  • 1 month later...
Got "Dirt" back in the garage for a head swap.  Decided to pull the motor out to do some cleaning & re-seal up the leaky bitch!.
Going from the stock oil burning 210 head to a W53 Peanut head.
PICS to come :fu:
