dp320 Posted May 13, 2013 Report Share Posted May 13, 2013 What is this? Is it original equipment? I don't see it on the wiring diagram. It has a coiled metal wire in it, it sort of seems like a fuse. 1 Quote Link to comment
Eagle_Adam Posted May 13, 2013 Report Share Posted May 13, 2013 looks like the piece i always remove when i swap to an el dizzy from points.... cant remember the fucking name Quote Link to comment
banzai510(hainz) Posted May 13, 2013 Report Share Posted May 13, 2013 when using points or a Pertronix ignition one needs a Ballast resisitor to keep the current low. 1 also uses the higher ohm point coil of usually 1.6 ohms. its there for a reason Quote Link to comment
mklotz70 Posted May 13, 2013 Report Share Posted May 13, 2013 Most parts stores will have replacements.....they're pretty cheap. Quote Link to comment
dp320 Posted May 13, 2013 Author Report Share Posted May 13, 2013 when using points or a Pertronix ignition one needs a Ballast resisitor to keep the current low. 1 also uses the higher ohm point coil of usually 1.6 ohms. its there for a reason So it's wired before the coil then? ETA: Nevermind, found plenty of diagrams on the web. The one I have says 1.6 OHMS when I cleaned it up. Quote Link to comment
