LeviGideon Posted May 10, 2013 Report Share Posted May 10, 2013 I'm in the process of getting the brakes working on the goon, so I pulled the brake master off the 4dr for now. I went to bench bleed it, but it wouldn't pull any fluid from the reservoir, just tons of suction from the bottom holes where the lines connect. Could there be a clog somewhere, or am I doing something entirely wrong? Quote Link to comment
Eagle_Adam Posted May 10, 2013 Report Share Posted May 10, 2013 gotta plug the bottom :) Quote Link to comment
Eagle_Adam Posted May 10, 2013 Report Share Posted May 10, 2013 then run a line from the valves to the reservoir and when the bubbles are gone ur good Quote Link to comment
LeviGideon Posted May 10, 2013 Author Report Share Posted May 10, 2013 I've plugged the bottom.... :sneaky: But even when I do that it doesn't create any suction at the reservoirs. I've got nothing at the bleeders, either. Quote Link to comment
Eagle_Adam Posted May 10, 2013 Report Share Posted May 10, 2013 what did you plug the bottom with? Quote Link to comment
LeviGideon Posted May 10, 2013 Author Report Share Posted May 10, 2013 I just put my fingers over the holes. haha Quote Link to comment
Eagle_Adam Posted May 10, 2013 Report Share Posted May 10, 2013 try a bolt, i used the fittings and lines i cut off another datto in the JY. air tight is the right way Quote Link to comment
banzai510(hainz) Posted May 10, 2013 Report Share Posted May 10, 2013 might need another set of fingers Put your fingers in the res and plug and pump the rod and see if it sucks then What does pulling from old 4 dr mean? was this a old master not used in years? Quote Link to comment
LeviGideon Posted May 10, 2013 Author Report Share Posted May 10, 2013 might need another set of fingers Put your fingers in the res and plug and pump the rod and see if it sucks then What does pulling from old 4 dr mean? was this a old master not used in years? It definitely hasn't been used in years, but it's fairly clean, and looks like it may have been replaced right before it was parked. Everything moves freely and smoothly. Quote Link to comment
LeviGideon Posted May 10, 2013 Author Report Share Posted May 10, 2013 Well, I let it sit for a while, then tried it again and it all works great now. Guess it just needed to soak in a little. Quote Link to comment
Draker Posted May 10, 2013 Report Share Posted May 10, 2013 Nice work! I'm jelly.. You're at home wrenching and I'm at work, working (and ratsuning :ninja:). Quote Link to comment
LeviGideon Posted May 10, 2013 Author Report Share Posted May 10, 2013 Eh, I don't start back working until Monday. Even then I make my own hours, so there's still datto time. Quote Link to comment
