TENDRIL Posted May 9, 2013 Report Share Posted May 9, 2013 so I've searched and have found a couple ways to do this, mine seems to have been the cheapest and easiest for a DIY. Total cost of materials was just under 30 $ usd the 9' of rubber will repair all 4 doors on the 510 wagon materials-clothes pins-adhesive (auto)-garage door bottom seal 9 FT.- 1/2 in. (or smaller if you can) flat top sheet metal screws tools-5/64 drill bit-drill-pliers-flat head-razor-atleast 2 ft.straight edge ruler (or like)-piece of 80gt sand paper -------------------------------------------------------------------------------------------------------------------------------------------------So first of all start off by removing the old squeegee.to do this, roll your window all the way down, take a flat head screw driver, and from the inside start to leverage(pry) a little bit at a time along the entire length of the chrome trim piece that the squeegee is stapled to until it pops off. now get the old rubber outthis can be frustrating, as most likely your staples are rusted, bend the old curled staple fingers straight as possible, than get a flat head under the other side of the staple work it up and off of the metal strip. some may be stubborn so just be patient and be careful! after removing old rubber proceed to clean the backside of the chrome trim piece using the 80gt sandpaper. after that, choose one of the staple holes from each of the staples. drill a 5/64 hole in the holes chosen.drill a hole in the corresponding staple holes along the metal strip. now get your garage strip, you must cut it to length. my strip was about 28 inches (for the front doors). you might want to cut a little more, so you have room to work with it. get your cut strip, and than cut it flush so that it will set on to the chrome trim piece. now you want to glue your new rubber to the chrome trim with the L shape facing the window (duh)with the adhesive less is more once the strip is glued straighten it out so the elbow of the rubber butts up against the lip on the chrome than place your clothes pins accordingly to keep pressure let dry for recommended time blah blah once dry take your metal strip, line up the holes that you drilled, set your screws i am going to replace the screws you see in the pics.since the button head ones would prevent the window mount from going all the way up by a hair (1/16 of an inch or smaller) flat head screws will prevent this. now depending on how long of screws you get you will have to file down (dremel or snip) the points not much but enough to clear the metal on the door. than carefully see if it works and if not adjust what doesn't I'm happy with itenjoy Edit: i should mention if you do not keep the elbow of the new rubber, under the lip of the chrome trim you will run into an issue of the squeegee sealing to far against the window and will be tough to roll down, so pay close attention when and where your gluing the rubber to the metal, i rushed the pass. side and and found this out, fixed when i moved the rubber elbow below the lip ... 2 1 Quote Link to comment
TENDRIL Posted May 9, 2013 Author Report Share Posted May 9, 2013 fuck i dont know what happend every thing just turned to html code when i posted edit just cleaned it up will add pics later sorry Quote Link to comment
MikeRL411 Posted May 9, 2013 Report Share Posted May 9, 2013 Sounds like a good fix. Should be adaptable to other vehicle models also. Creativity keeps old Datsuns running. Quote Link to comment
Draker Posted May 9, 2013 Report Share Posted May 9, 2013 fuck i dont know what happend every thing just turned to html code when i posted edit just cleaned it up will add pics later sorry That shit always happens to me too. I have been copying the ad before I post it just in case that happens.. cause it SUUUUUUCKS fixing it.. Now.. how about those pics you were talkin' boot. Quote Link to comment
qwik510 Posted May 10, 2013 Report Share Posted May 10, 2013 Very nice Ratsun replacement. Good Job! Quote Link to comment
Laecaon Posted May 10, 2013 Report Share Posted May 10, 2013 I think the Hang510 method is long lost on this forum... Hang glued wiper blade refills to the outer trim... Quote Link to comment
DatMo Posted May 10, 2013 Report Share Posted May 10, 2013 this is great. now what about the inner? haha. i need all the rubbers for my windows replaced. this seems like an easier replacement Quote Link to comment
TENDRIL Posted May 10, 2013 Author Report Share Posted May 10, 2013 yea ive been thinking of a way ^^ :ninja: Quote Link to comment
D52E Posted May 10, 2013 Report Share Posted May 10, 2013 I believe the inner door squeegees are still available from Nissan for the 2 door model. RH 80835-26501 LH 80836-26501 See item #7 and 8 - http://www.carpartsmanual.com/datsun510/Datsun510Index/BodySedan/FrontDoorTrimming/2Door/tabid/844/Default.aspx 1 Quote Link to comment
Ratwagon1600 Posted May 10, 2013 Report Share Posted May 10, 2013 I like it! Very Ratsun. Quote Link to comment
