xlr8r Posted May 5, 2013 Report Share Posted May 5, 2013 Bluebird badge- Not sure exactly what model this came off of. It’s in good shape but has no nubs on the back- $15 Roof Rack As cool as racks are I’m not going to put this on my wagon. Seems to be fairly complete though it only has one crossbar. The small bars that sit on the roof itself have the rubber backing intact.- $100 Z32 Rear Calipers- Pair of rear Z32 aluminum calipers with lots of life left to the pads- SOLD Z31 Diff Low mileage Z31 turbo (84) 3.54 R200 differential. Only had around 50,000 miles on it. This is the newer/stronger longnose R200 diff the uses the same ring gear bolt size as 240sx R200 diffs allowing you to use any of the many 240sx LSD’s. $60 Differential bushings- Brand new Energy Suspension differential bushings, part #7.1108R for Z32’s. It’s my understanding they can also be used for S14 240sx’s. - $30 Pressure Relief Valve- This is the real deal. Greddy adjustable Pressure relief valve. Will thread right into your L28et manifold, and some other engines (this was on a FJ20et) for more adjustment and a better look/sound. It’s my understanding that it can adjust up to around 15lbs of boost- $80 810 Door & hatch cards- I have a complete set of fairly decent shape brown cards from a 1978 810 wagon. This is everything: front & rear doors, rear hatch sides & hatch cards. The card structure to all of them is in great shape. I’ll include any other brown trim items I find in the garage- $100 Grill & Bezels This is a grill and headlight bezels for 77-78 810’s. The grill is in 7 of 10 condition with the expected wear & aging.The passenger side bezel has chrome peeling off while the driver’s side seems to be in great shape. All but one mounting tab is there in this set!!- $100 1 Link to comment
