satcat808 Posted May 4, 2013 Report Share Posted May 4, 2013 How much lower from stock height can I lower my front end by torsion bar adjustment. I tried to adjust mine but it never raised or lowered, I can't really figure out how this works. Is there a top nut I need to hold. When I look at the torsion end I can easily get to the bottom bolt but now way to get to anything on the top end since it looks like its all enclosed. Thanks for the help. 2 Quote Link to comment
wayno Posted May 4, 2013 Report Share Posted May 4, 2013 The 320 has a shaft that somehow the torsion bar adjustment bolt threads into, it has been so long since I have been under there, that I cannot recall how it seats itself, if you turn both nuts so the torsion bar arm looks the same on both sides, then lower the truck back down on it's wheels and roll the truck 10 feet or so, and let it settle, then decide if you need to go down or up. Make sure that the bolt going threw the shaft has enough threads going in to it, if not, then you will need to re-index the torsion bars themselves at the lower control arm connection itself. This is what mine looks like while all 4 wheels are on the ground. This is what my LCA torsion bar connection looks like(dirty isn't it), if you run out of adjustment in the cross member, then your torsion bar will likely need re-indexed at this point, make sure you mark everything before taking it apart so you know how it was when you put it back together. If you can find someone with a set of these that is willing to sell them, it the best way hands down to lower the front of your 320, you get a 2 inch drop without giving up your stock ride. https://www.google.com/url?q=http://community.ratsun.net/topic/43421-320-zd-lower-control-arm-2-drop-250-shipping/&sa=U&ei=dYWFUb6mNeW8iwKr54CABg&ved=0CAcQFjAA&client=internal-uds-cse&usg=AFQjCNEmYKz-PxQFdzdTqn-QcZYYByyHdg Quote Link to comment
satcat808 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Thanks Wayne it work! By dropping both sides I got about 1.5 " drop in the front. I added 2" drop blocks in the rear and now the stance looks way better!!!! Thanks again for all the help and information. Mahalo, Dean Quote Link to comment
wayno Posted May 5, 2013 Report Share Posted May 5, 2013 Thanks Wayne it work! By dropping both sides I got about 1.5 " drop in the front. I added 2" drop blocks in the rear and now the stance looks way better!!!! Thanks again for all the help and information. Mahalo, Dean How about a couple photos of the new stance Dean, that way other 320 owners might decide they like it, and drop theirs a couple inches also. We like photos a lot on here. :D Quote Link to comment
satcat808 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Here are some new pics of the new stance. Still got to adjust and tighten some things up but over all dropped 2" in the back and about 1.5" in the front. Thanks again Wayne... [/url [/url] [/url] This was the original Factory Stance. Quote Link to comment
Phil Dentz Posted May 5, 2013 Report Share Posted May 5, 2013 That's a nice looking truck! :thumbup: Quote Link to comment
datzenmike Posted May 6, 2013 Report Share Posted May 6, 2013 All torsion bar adjustments will change the toe slightly so be aware of this. It may be nothing to WTF!!! I noticed mine most when driving through puddles. Quote Link to comment
KFunk740 Posted May 6, 2013 Report Share Posted May 6, 2013 satcat808: do I remember your username from FH / Speedhawaii.com from way back, and/or HT? kfunk / funkman here. I have relocated. :) Quote Link to comment
satcat808 Posted May 7, 2013 Author Report Share Posted May 7, 2013 satcat808: do I remember your username from FH / Speedhawaii.com from way back, and/or HT? kfunk / funkman here. I have relocated. :) Aloha KFunk740 Yup that would be me on FH / Speedhawaii.com you're living in Ohio now??? Quote Link to comment
KFunk740 Posted May 7, 2013 Report Share Posted May 7, 2013 Aloha KFunk740 Yup that would be me on FH / Speedhawaii.com you're living in Ohio now??? Aloha, brah! I can't remember if we talked much on there, or if we even met in person (it's possible). But yep, I finished at UH, and got tired of bouncing around jobs with unreliable funding and dealing with traffic. I packed up and sent the '74 BMW to San Francisco, and then drove it here to Ohio. I've been doing research full-time and teaching part-time, and will soon switch to teaching full-time. Bought a house, a pick-up truck, got engaged, and all that stuff. Hawaii is a beautiful, special place.... but living in the country makes me a lot happier. Quote Link to comment
Zeke- Aus- Li Posted May 7, 2013 Report Share Posted May 7, 2013 farrk me dead thats a nice L ee Quote Link to comment
KFunk740 Posted May 8, 2013 Report Share Posted May 8, 2013 By the way, what size/type of tires do you have? Those the stock 14x4JJ wheels? How is the ride/handling with them? Your truck looks great, and I've finally got to pull the trigger on similar tires. Almost done putting coats of paint on my stock wheels, and am thinking about ordering 185/75-14 or 195/75-14 Hankooks. Mahalo, Kevin Quote Link to comment
satcat808 Posted May 11, 2013 Author Report Share Posted May 11, 2013 By the way, what size/type of tires do you have? Those the stock 14x4JJ wheels? How is the ride/handling with them? Your truck looks great, and I've finally got to pull the trigger on similar tires. Almost done putting coats of paint on my stock wheels, and am thinking about ordering 185/75-14 or 195/75-14 Hankooks. Mahalo, Kevin Howzit Kevin, Here is the tire tire size I got. 205/75/14 GT W/W TIRES. Mahalo. Dean Quote Link to comment
KFunk740 Posted May 11, 2013 Report Share Posted May 11, 2013 Howzit Kevin, Here is the tire tire size I got. 205/75/14 GT W/W TIRES. Mahalo. Dean Whoa, that's really wide! I thought 195 would be a stretch, and hadn't even considered 205s. If it works well though, then that'd be great. That'd be over 26" total diameter, which is pretty close to the original size. If they stay on the 4" wide rims and don't handle like crap, then I may have to consider that. Quote Link to comment
satcat808 Posted May 11, 2013 Author Report Share Posted May 11, 2013 Whoa, that's really wide! I thought 195 would be a stretch, and hadn't even considered 205s. If it works well though, then that'd be great. That'd be over 26" total diameter, which is pretty close to the original size. If they stay on the 4" wide rims and don't handle like crap, then I may have to consider that. Yeah I had a hard time finding stock size with white walls. This was the best I could do they are a little tall but still work ok for me.... Good luck Aloha Dean Quote Link to comment
66Fairlady Posted June 5, 2013 Report Share Posted June 5, 2013 I have a pair of Mike's 320 Z'd lower control arms. $200. Ted. tcheaton@hotmail.com Quote Link to comment
6l320datsun3 Posted June 7, 2013 Report Share Posted June 7, 2013 I must say it looks much cleaner lowered since there isnt as much of a distance from the ground under it. Nice truck man just ... NICE! Quote Link to comment
kwoo510 Posted June 16, 2013 Report Share Posted June 16, 2013 I am thinking to lower mine, too. What lowering kit do you use? Quote Link to comment
satcat808 Posted June 18, 2013 Author Report Share Posted June 18, 2013 I am thinking to lower mine, too. What lowering kit do you use? Any universal drop kit will fit. I got my 2" drop kit from O'rilleys. Quote Link to comment
kwoo510 Posted June 18, 2013 Report Share Posted June 18, 2013 Any universal drop kit will fit. I got my 2" drop kit from O'rilleys. thanks Quote Link to comment
