Eagle_Adam Posted May 3, 2013 Report Share Posted May 3, 2013 Just picked up an 01 altima alt to upgrade my girls goon, but now i need a "core" to turn in. Problem is all my are still good and i dont wanna get rid of them. Im hoping someone local has one i can buy on the cheap to turn in as a core Link to comment
datzenmike Posted May 4, 2013 Report Share Posted May 4, 2013 Adam, wait until Canby and you can pick my brains on this swap and see first hand what's needed. The only possible weak point was the shortened nut to hold the pulley on. About 4-5 threads. I used LocTite type compound and used an impact wrench to put it on then a center punch to peen the metal over so it can't come loose easily. If I ever have it off again I will tac it with my TIG. It's highly unlikely that I would ever need to have to remove the pulley ever again. If you do the swap I would recommend a small tac. Link to comment
Eagle_Adam Posted May 5, 2013 Author Report Share Posted May 5, 2013 Thanx mike, I bought the alt and the swap is going down, probably before canby to be honest. But I'll find someone local with an impact and welder to help :) This canby locked ;) Link to comment
