810wagn Posted May 2, 2013 Report Share Posted May 2, 2013 I was staring at my motor earlier today and I saw this hole that I hadn't noticed before, What is it for and does it need to be plugged or does something go into it? Im confused... Quote Link to comment
Eomund Posted May 2, 2013 Report Share Posted May 2, 2013 I'll take a look at my motor when I get home to confirm, but that looks like a freeze plug hole. Quote Link to comment
datsunaholic Posted May 2, 2013 Report Share Posted May 2, 2013 It's for the PCV. The location threw me- I'm used to 4-cyls being midblock. Didn't realze 6-cyls were so far forward. No, you don't want to plug that. Quote Link to comment
TENDRIL Posted May 2, 2013 Report Share Posted May 2, 2013 nope do not plug it! you will star blowing valve cover gaskets oil pan, mains sometimes, and cause other issues .. Quote Link to comment
darrel Posted May 2, 2013 Report Share Posted May 2, 2013 When you turn the engine upside down, there is a plate held on by two screws, behind the plate is a mesh screen folded a few times. Basically a flame arrestor. Quote Link to comment
datzenmike Posted May 3, 2013 Report Share Posted May 3, 2013 I don't think a flame arrestor as the PCV valve is a spring loaded one way valve that closes if there in an intake backfire. The 'fly screen' is to provide a large porous surface for oil mist to precipitate on and run down into the pan Quote Link to comment
810wagn Posted May 3, 2013 Author Report Share Posted May 3, 2013 Ahh, crankcase breather.. duh. Thanks guys! How is the vent tube held in there? Does it get pressed in? I just don't see anything that would secure it on there so oil doesn't seep out. Quote Link to comment
datzenmike Posted May 3, 2013 Report Share Posted May 3, 2013 It's just a very snug slip fit. The tube is supported elsewhere and can't fall out. Quote Link to comment
810wagn Posted May 3, 2013 Author Report Share Posted May 3, 2013 Cool, thanks for the help! Quote Link to comment
