Help Identifying Transmission
  • Replies 3
Looks like a 521 rear mount and the clutch arm is adjustable too. '77-'78 280z, first year ('79) 280zx or '77-'78 620 were 5 speeds that only had a reverse light switch. The 810s had a neutral switch and the '79 620 had a top gear switch added. As Wayno said it's not an '80 or newer.
Most likely a 620 then a 280z. You can tell everyone it's from a Z car if you want, the truck transmission was exactly the same, gear ratios... everything
Yes i was told by the previous owner its was in a 521 and i'm sure you guys are right that its from a 620. I am thinking of puting it for sale, just wanted know what i'm selling
Thanks for the info guys.
