wtb 1979 620 signal switch
  • Replies 15
C'non noob. You know what you have and want but you have to communicate to everyone else what's needed. Many parts don't fit all years as they are up graded or modified.
Up to '77 there is a 6 plug connector plus two separate wires... one for horn (female connector) and one for the turn signal flasher unit (male connector)
From '78 up there is a single 10 pin connector only.
I reconditioned one from a '79.
Clean and lube, worked wonders for an extra one I have. I plan on doing the same to the one in the truck now.
Disassembled it, dipped the contacts in vineger overnight, cleaned old grease off and regreased the contact and pivot points.
Continuity checked per the factory service manual.
