Ryno620 Posted April 24, 2013 Report Share Posted April 24, 2013 Can people that have shaved door handles post up pics of where you put manual door poppers please? Quote Link to comment
Wide14u Posted April 24, 2013 Report Share Posted April 24, 2013 i didn't use poppers or do you mean solenoids Quote Link to comment
Ryno620 Posted April 24, 2013 Author Report Share Posted April 24, 2013 In Aus you've got to have a manual way on the outside to open the doors for it to be legal Quote Link to comment
Wide14u Posted April 24, 2013 Report Share Posted April 24, 2013 can it be a electric button Quote Link to comment
Ryno620 Posted April 24, 2013 Author Report Share Posted April 24, 2013 I dont know the rulings that specifically to be honest Quote Link to comment
Ryno620 Posted April 24, 2013 Author Report Share Posted April 24, 2013 The door mechanism looks easy enough to just have the rod come straight up through the door but i dont want it to be rough. My plans were to french it into the door so the button sits flush just above the bullet but im unsure if it will defeat the purpose. I have shit doors to trial ideas on Quote Link to comment
Laecaon Posted April 24, 2013 Report Share Posted April 24, 2013 Leave the lock, shave the door. Attach the handle rod to the lock. Now the lock is the handle... 2 Quote Link to comment
Pacific coast Datsun Posted April 24, 2013 Report Share Posted April 24, 2013 I did this on my Hardbody or...D 21. Shaved handle & lock...extended the rod that used to connect to the handle that opens the door...drilled a 1/4 inch hole on top of door...extended rod pokes out of said hole 1 inch...screw on chrome interior door lock pull & bam ! Push down on rod to open the door. Quote Link to comment
datzenmike Posted April 24, 2013 Report Share Posted April 24, 2013 In Aus you've got to have a manual way on the outside to open the doors for it to be legal Imagine the first person to get to you's surprise when they try to open the door to get you out of your burning truck. 2 Quote Link to comment
1lo620 Posted April 25, 2013 Report Share Posted April 25, 2013 I did this on my Hardbody or...D 21. Shaved handle & lock...extended the rod that used to connect to the handle that opens the door...drilled a 1/4 inch hole on top of door...extended rod pokes out of said hole 1 inch...screw on chrome interior door lock pull & bam ! Push down on rod to open the door. Here is what Mark is talking about, this truck is a friend of mines and that is what he did.. You can see the rod up my the window slot.. that is the door handle.. Now on my truck when I shaved the lock and handle. I mounted the selonoid inside the door on the side that has the latch on it. So the mounting bolts arent in the way.. I had remote/keyless entry, but my friend that installed it for me added a hidden swtich just in case you lock your keys in... Quote Link to comment
]2eDeYe Posted April 25, 2013 Report Share Posted April 25, 2013 Leave the lock, shave the door. Attach the handle rod to the lock. Now the lock is the handle... This is what I did. :) 1 Quote Link to comment
Ryno620 Posted April 25, 2013 Author Report Share Posted April 25, 2013 Thanks for all the feedback. 2eDeYe i thought the door mechanism needs to push down, how did u get the lock to do that? Cause i know it goes sideways. And then is your only entry by key? Quote Link to comment
1lo620 Posted April 26, 2013 Report Share Posted April 26, 2013 that is they way my doors are on my Chop top.. I just use the key to open the door.... easy and no worries of dead batteries and not being able to get in to the truck... lol !!!! Quote Link to comment
Aibast Posted April 30, 2013 Report Share Posted April 30, 2013 Imagine the first person to get to you's surprise when they try to open the door to get you out of your burning truck. +1 on that Quote Link to comment
Ryno620 Posted April 30, 2013 Author Report Share Posted April 30, 2013 Just so everyone knows, im not opposed to having a visable external manual way of opening the doors. I just wanted a clean way of doing it that worked in with the particular styling of the bulletside doors Quote Link to comment
cruznude Posted April 30, 2013 Report Share Posted April 30, 2013 The entry with your key is the way to go. I've done this in the years past and it is great! Just have a spare key in your wallet or elsewhere so when you go gas up you don't lock them inside by accident. Show us some pics and let us know how it comes out. Quote Link to comment
datzenmike Posted April 30, 2013 Report Share Posted April 30, 2013 Just so everyone knows, im not opposed to having a visable external manual way of opening the doors. I just wanted a clean way of doing it that worked in with the particular styling of the bulletside doorsJust trying to be the voice of reason here that's all. In a panic situation a would-be rescuer will reach for a door handle that he is used to seeing and it's not there. Would he have the sense to feel around for another lever? Would he even figure out that it's a push button electric solenoid? Things to think about. Quote Link to comment
]2eDeYe Posted April 30, 2013 Report Share Posted April 30, 2013 Just trying to be the voice of reason here that's all. In a panic situation a would-be rescuer will reach for a door handle that he is used to seeing and it's not there. Would he have the sense to feel around for another lever? Would he even figure out that it's a push button electric solenoid? Things to think about. I think any rescuer would break out the window. In an accident you never know what will not work anymore anyways. I usually have something in the car I can used to break out the window from the inside. Need to pick up a couple emergency glass hammers like I've been meaning to. Thanks for all the feedback. 2eDeYe i thought the door mechanism needs to push down, how did u get the lock to do that? Cause i know it goes sideways. And then is your only entry by key? You can see the modified linkage in the pictures I posted. Basically you set up the linkage to activate the door latch with the key lever. Quote Link to comment
datzenmike Posted April 30, 2013 Report Share Posted April 30, 2013 Yes rescue personnel but what about about at night, you're knocked out and some old man or kid is the first one by? I say never walk into a room that has no exit. I suppose they may throw a rock through the window because the door would be jammed anyway. Quote Link to comment
cruznude Posted May 1, 2013 Report Share Posted May 1, 2013 The entry with your key is the way to go. I've done this in the years past and it is great! Just have a spare key in your wallet or elsewhere so when you go gas up you don't lock them inside by accident. Show us some pics and let us know how it comes out. Look, its really simple. Once you disconnect the linkage from the door handle, take a good look at where it needs to go on the lock. And go from there.... Quote Link to comment
