Markiewicz89 Posted April 20, 2013 Report Share Posted April 20, 2013 Looking to buy a 5-speed manual transmission for a 1979 Datsun 210/B310 Coupe (Hatchback). Thanks. :thumbup: I'm also considering 4-speed manual transmission. Which is a F4W60. The input and output shafts should be 20mm (about 25/32") diameter and 18 spline.The serial number on top of the bell housing should begin with the letter "F" (FL, FA, FX etc. OK). The number "60" is cast into the right side of the main case. These transmissions come from the Datsun B210 or Datsun 210/B310. The model number for the transmission, FS5W60A or FS5W60L, is sometimes found on the Serial Number Plate on the firewall. This is not found on the transmission. Note: Dogleg Pattern or Regular Shift Pattern. Either will work for me. Link to comment
