jvb5577 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Thanks for the info! I'll get a new sprocket so timing can be exact. Quote Link to comment
Sealik Posted April 20, 2013 Report Share Posted April 20, 2013 Thanks for the info! I'll get a new sprocket so timing can be exact. Buy the whole kit Quote Link to comment
jvb5577 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Well took everything just about apart to see how it was. Front timing cover is broken :sneaky: No wonder there was so much RV sealant around this. Also one of the threads that hold the head to the block seems to be stripped on the block. It is one of the middle ones. Bolt came out but upon inspection I can see they are rounded in the head. Here are the pistons Pretty clean and smooth The valves look nasty You can see the bottom middle bolt is oily, that is the one that is stripped in the block Quote Link to comment
Stoffregen Motorsports Posted April 21, 2013 Report Share Posted April 21, 2013 I bet the block is cracked. That's why the threads stripped. Quote Link to comment
jvb5577 Posted April 21, 2013 Author Report Share Posted April 21, 2013 I gave the block a good look threw and didn't see any cracks but to be positive this thing would need to be hot tanked. Quote Link to comment
jvb5577 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Going to be picking up a Z22E block today for $150 complete. :D Pictures will follow once I get it back as it is still in the vehicle '82 200sx. Quote Link to comment
heretic Posted April 22, 2013 Report Share Posted April 22, 2013 :rofl: What are you planing for your build? :) single sidedraft LZ23 Quote Link to comment
jvb5577 Posted April 22, 2013 Author Report Share Posted April 22, 2013 Do you already have your Z motor? Quote Link to comment
heretic Posted April 22, 2013 Report Share Posted April 22, 2013 I have not. My initial plan was to use a Z22 but now I'm contemplating a Z20. I'm watching your thread close :)) Quote Link to comment
jvb5577 Posted April 22, 2013 Author Report Share Posted April 22, 2013 Well here it is.. The Z22E All the intakes are clean This is where it sits at TDC Quote Link to comment
jvb5577 Posted April 23, 2013 Author Report Share Posted April 23, 2013 Got the head off. It will be for sale if anyone is interested. It is fuel injection. Quote Link to comment
jvb5577 Posted April 23, 2013 Author Report Share Posted April 23, 2013 Okay guys and gals, I am going to start to collect parts for this build. I am planing this from the jason grey: Big Bore 2.3L KA24 pistons into a bored Z20/Z22/L20B block. The small 2.8cc dish area of the KA24 pistons helps to preserve compression ratio even with the low piston deck height. Compression ratio with a open chambered U67 head is 9.9:1 or use dished Z24 pistons and peanut chambered head for 8.9:1 compression ratio.Parts: Z22 crank, KA24 pistons, Z22S/ L20B rods in a +2mm bored Z22 block or +4mm Z20/L20B block.s/2+r+p= 92/2+145.9+34.0= 225.9 mmpiston deck height: -1.55mm below deck I have some questions. What would be a good cam to use for this setup? Say I am going with the U67 open head. Also going to use as a DD What valves, springs, ect. should be fitted to the head? Can I use the Z22 alternator? I need the KA24e pistons out of a truck? 1 Quote Link to comment
Dawa Posted April 24, 2013 Report Share Posted April 24, 2013 so you havent decided on which block huh? Quote Link to comment
jvb5577 Posted April 24, 2013 Author Report Share Posted April 24, 2013 I am going to use the Z22E block, guess i forgot to mention that. Quote Link to comment
jvb5577 Posted April 27, 2013 Author Report Share Posted April 27, 2013 Just took the pistons out. Rings seem to be in good shape. I noticed there are a lot of drill marks on the crankshaft. Is this like this out of the factory or did someone balance it? Quote Link to comment
Stoffregen Motorsports Posted April 27, 2013 Report Share Posted April 27, 2013 Those are factory balance holes. Most shops balance by grinding away material. Nissan/Datsun engines are famous for being within 4 grams balance anyway, so unless you're changing rods or pistons, I would leave it alone. Quote Link to comment
jvb5577 Posted April 27, 2013 Author Report Share Posted April 27, 2013 Thanks! Okay I have been looking for a set of KA24e pistons. Don't want to spend anywhere near $400. Should I just go with stock pistons from a D21 or 240sx? OR will a pair of cheap ones that go for $150 with pistons and rings be recommended? I still need the cylinders measured, if they are well within spec I may just have them honed and new rings on the pistons to keep cost down for say a R1 carburetor setup? Why does there have to be so many options to this build :hmm: Quote Link to comment
Stoffregen Motorsports Posted April 27, 2013 Report Share Posted April 27, 2013 There are three different sytle KA24 pistons that I can remember; early pistons, late pistons and 16 valve pistons. The dish is different on all of them. Quote Link to comment
jvb5577 Posted April 30, 2013 Author Report Share Posted April 30, 2013 Good to know. I am pretty sure I need the early ones from the KA24e? I have the block bare and was looking at the crankshaft bearings. One is worn down the the brass looking finish. Should these be replaced? 1 Quote Link to comment
banzai510(hainz) Posted April 30, 2013 Report Share Posted April 30, 2013 if your that far just replace the bearings with new ones. 99% of the time STD size bearings. Quote Link to comment
jvb5577 Posted April 30, 2013 Author Report Share Posted April 30, 2013 What manufacture would you recommend for the bearings? Quote Link to comment
datzenmike Posted April 30, 2013 Report Share Posted April 30, 2013 Good to know. I am pretty sure I need the early ones from the KA24e? I have the block bare and was looking at the crankshaft bearings. One is worn down the the brass looking finish. Should these be replaced? . Abso freeking lutely!!! . There are three different sytle KA24 pistons that I can remember; early pistons, late pistons and 16 valve pistons. The dish is different on all of them... The first few months of the S13 there were 9 to one compression (slightly domed) KA24E pistons 12010-40F10. From November '88 on the S13 pistons were 2.8cc dish 8.6 compression pistons 12010-30R12. The truck KA24E pistons were similar to the 12010-30R12s above, but not cut for C clips to retain the floating pins. They were the same, but different, and with a different number. The S14 KA24DE has a vastly smaller combustion chamber and so has a much larger piston dish. Probably around 11cc or so. 12010-53F00 The truck KA24DE pistons were similar to the 12010-53F00s above, but not cut for C clips to retain the floating pins. They were the same, but different, and with a different number. Quote Link to comment
jvb5577 Posted April 30, 2013 Author Report Share Posted April 30, 2013 Mike for the LZ build based on the Jason Grey information I would want the KA24E truck pistons with the 2.8cc dish? I won't mind running higher octane fuel with the higher compression. Quote Link to comment
GreaseMonky Posted April 30, 2013 Report Share Posted April 30, 2013 What manufacture would you recommend for the bearings? I was told Clevite brand bearings, that say NDC on them, i have part # if you want for atleast standard size Quote Link to comment
