Bad gauge cluster voltage regulator? Easy $2 fix.
aintnobiscuit
Are your turn signals working???? They are on the same fuse as the VR. If working, then not the fuse.
I think this is the 521 VR. Remove and carefully pry the case off and clean the contacts inside.
  • 1 year later...
  • Replies 83
  • 11 months later...
  • 3 weeks later...
UPdate on the 9 Volt Reg.
Since it seems like 8.6 is the actual voltage needed the gauge reads alittle higher on both Gas and Fuel.
maybe if one orders a bunch one could find the best of the bunch of a 7908 VR and see if reads higher and pick that one
https://www.amazon.com/Aisin-WPN-032-Engine-Water-Pump/dp/B008EEZ3A6
Edited by banzai510(hainz)
From the LM7809 datasheet
Quote
In addition, to use as fixed voltage regulators, this device can be used with external components to obtain adjustable output voltages
i'm wondering if this is as simple as adding two resistors?
