Bad gauge cluster voltage regulator? Easy $2 fix.
aintnobiscuit
I just put one of these in my car , I was having intermittent fuel and temp guage  one day it worked next minute it didnt
I am excited to see if this cures my problem
  • Replies 83
Oh man, that looks awesome! Good job! I'm going to do the same thing now!
:w00t:
It does work, and pretty well. Here's a vid. I forgot to post it a while back. I wish there was a way to make it work faster, but I'm just happy it's working.
  • 5 months later...
  • 1 year later...
Well if it's set up right, I'm almost on E and my temp is bad. At one point
I reversed the 12v and 9v just to cover my
Bases cause Im not wiring guru lol, the fuel registered half a tank and the temp was high.
Turned the car off. After a bit, turned it on, no temp reading.
I'm going to rip my eyes out.
I'll hit it again tomorrow. It's 1:09 am
  • 1 month later...
The temp gauge still sucks .CLEAN THE SENDER AT THE STAT. could be just a bad sender. I seen them go bad. but hard to get thm out of housing w/o breaking them. I usually just swap a whole another housing to conferm the proplem.
What is the stat?
Different question, how much voltage is supplied to the sender itself. Is it just straight 12 volts?
The fuel sender is a variable resistor ground.
The temp sender is temperature affected ground.
Back to the basic question!  NO 12 volts is NOT applied to the sensor.  The regulated 8.6 mechanicaly regulated voltage  [or 9 volts if you use the electronic regulated item specified in the basic subject entry!] is applied.  The resultant current flow is applied to the meter which should dampen the almost square wave 8.6 or electronic 9 volts and give a "correct" reading.
  • 1 month later...
  • 7 months later...
Hi,
I was wondering if the articular you posted for the cluster voltage regulator was for the 1966 mustang? I was wondering if the original could be replaced in my 1966 ford mustang. they are way to much for the size of them and would really appreciate if you had a chance to reply. would much rather go the way you did but i might need some kind of diagram or some info.
Thank you
Russ
thanks, for the reply datz, not sure if my last response made it but back to you, below, one of your members who posted original , had a mustang for one of his cars , and it came up on a search for mustang voltage regulators for gage cluster, thanks again :) intnobiscuit
Member Since 24 Feb 2012
Offline Last Active Jun 29 2015 04:09 PM star_off.pngstar_off.pngstar_off.pngstar_off.pngstar_off.png
Community Stats
  • Group Senior Member
  • Active Posts 892
  • Profile Views 3,121
  • Member Title Senior Member
  • Age 33 years old
  • Birthday October 2, 1982
    mystery.png Not Telling
    Newport Beach
    1969 datsun 510, 1970 datsun 521, 1966 mustang, 2013 BMW M3
    space, rockets, cars, engines, displacement modifiers, arduino, linux
  • Occupation
    software engineer
