wayno Posted February 8, 2014 Report Share Posted February 8, 2014 I would leave it alone also, how many 620s have you seen driving around with your fiberglass package, you likely have not seen any but yours. You have done so much so far, I would have made it a hardtop/convertible, but that is me, I guess I am weird. 2 Quote Link to comment
denmarkboy Posted February 8, 2014 Author Report Share Posted February 8, 2014 well the 5 lug swap should be pretty easy. the way i would do it would be to start with a balljoint conversion. upper A arms have to be made or bought to do this. for the rearend, a narrowed 8.8 with disks could work.. hope it helps. the 8.8 does most of the work for me and i can get those all day long for $ 200 .. and the ball joint swap, i knew i would have to do a brake upgrade someday. ive bookmarked a dozen swap threads,wish i could do bags. but when the motor is in there isnt much room to go down .(not with this wheel and tire combo) thnkx 2 Quote Link to comment
denmarkboy Posted February 8, 2014 Author Report Share Posted February 8, 2014 I'd keep the fiberglass, really gives the truck a unique look. Up to you though :) the main reason i ask is it is going to be just as much work to fix and save it as it will be to remove it . i do like the look of the truck, but it is clearly from the 80's. but now that i've done the top its also clear this isnt a normal animial. i almost feel like i have 2 ideas starting to go in different directions. and i feel the same about the grill/headlights, i like it but just like all the roundness of the 620, the square stuff is a style , just not sure what to do. 1 Quote Link to comment
denmarkboy Posted February 8, 2014 Author Report Share Posted February 8, 2014 I would leave it alone also, how many 620s have you seen driving around with your fiberglass package, you likely have not seen any but yours. You have done so much so far, I would have made it a hardtop/convertible, but that is me, I guess I am weird. well your right about that, they are from another time.and i dont think your weird i have had 3 620 hardtop conv. 1 521 ,i love em .if i still lived in cali i would still have one. so after getting it back i knew i would have to make the top solid. its to wet here and i dont want it to be a garage only rig. i have to many projects. i am upgrading the wheels to one of these 2 options . i am leaning towards the all polished one Quote Link to comment
denmarkboy Posted February 13, 2014 Author Report Share Posted February 13, 2014 well i came to do an update, but my (reply to this topic) window does not give me the option to ad pictures anymore . oh well, its kind of a pain in the ass anyway. i would rather let the pictures do the talkin,but honestly i hate fuckin com-put-ers. they are usually more of a pain than a positive ! ( in my life ) . so i re re ran the brake lines, and until i do a tire and wheel upgrade i cant do disc in the front.i am stripping engine bay of everything and started smoothing everything out & paint.i replaced the fuel lines,remounted the trans cooler,moved all the wires from the engine bay,streamed and stripped all the frame back to the torsion bar cross member. doin undercoating today and then the engine back in tomorrow. 1 Quote Link to comment
ggzilla Posted February 13, 2014 Report Share Posted February 13, 2014 i do like the look of the truck, but it is clearly from the 80's. Or is it clearly from the 70s? if you are old enough to remember. 1 Quote Link to comment
]2eDeYe Posted February 13, 2014 Report Share Posted February 13, 2014 If you are using Internet Explorer 11 then that is why you can't post pics. It doesn't cooperate with the forum software for some reason. Quote Link to comment
denmarkboy Posted February 13, 2014 Author Report Share Posted February 13, 2014 If you are using Internet Explorer 11 then that is why you can't post pics. It doesn't cooperate with the forum software for some reason. I will check when I go back inside , I use a couple of different laptops, never really paid attention. Thnks Quote Link to comment
denmarkboy Posted February 13, 2014 Author Report Share Posted February 13, 2014 Or is it clearly from the 70s? if you are old enough to remember. Well I am only a couple of years younger than you so I probably remember as much of the 70's as you . I guess I was thinking about the headlight and flare combo. Quote Link to comment
ggzilla Posted February 13, 2014 Report Share Posted February 13, 2014 Square headlights came out in 1975 and became a rage in minitruckin. They forgot about the classics for a while. 1 Quote Link to comment
Steroid Posted February 14, 2014 Report Share Posted February 14, 2014 Remember that things were done in succession. First, wide tires were installed. Then We got pulled over for them being too wide. Next We just put on flat plastic or metal mudflaps. This was in the mid 70s. Next was fender flares. In the late 70s everybody was going with a new look......... narrow rims, NO fender flares and just an airdam up front. Your truck's look is from the late 70s/ very early 80s. 2 Quote Link to comment
denmarkboy Posted February 14, 2014 Author Report Share Posted February 14, 2014 Remember that things were done in succession. First, wide tires were installed. Then We got pulled over for them being too wide. Next We just put on flat plastic or metal mudflaps. This was in the mid 70s. Next was fender flares. In the late 70s everybody was going with a new look......... narrow rims, NO fender flares and just an airdam up front. Your truck's look is from the late 70s/ very early 80s. I guess based on what knew,remembered,have learnt since. This 620 is a 77 , it never saw fiberglass until 82 /83 , but I do remember all those trends to . I like all the different looks , 1 Quote Link to comment
Spoona_Jay21 Posted February 15, 2014 Report Share Posted February 15, 2014 well your right about that, they are from another time.and i dont think your weird i have had 3 620 hardtop conv. 1 521 ,i love em .if i still lived in cali i would still have one. so after getting it back i knew i would have to make the top solid. its to wet here and i dont want it to be a garage only rig. i have to many projects. i am upgrading the wheels to one of these 2 options . i am leaning towards the all polished one Personally I really like these rims. i think if you go with the right size, it would look great! 1 Quote Link to comment
Rushnracin Posted February 16, 2014 Report Share Posted February 16, 2014 Haven't seen or heard NAMTO referred to in many years. Used to be a member in that time period. National association of mini truck owners. Also hooker headers used to sell the engine swap kit used here. I still have new glass fire wall and trans mount for this install. Some same parts used with 3.8 Buick and TH350 also used by Low Mfg 2 Quote Link to comment
Steroid Posted February 17, 2014 Report Share Posted February 17, 2014 Another vintage dude ! ! PM Me Rushnracin. Robbie Klima now lives in My town and I also tracked down Marty Smith, Don Lindfors, Eric Thorsen and others. I purchased Jay Wasserman's old show truck about 6 years ago. Spencer Low now lives in Colorado. Good to have You on board ! ! 2 Quote Link to comment
denmarkboy Posted February 19, 2014 Author Report Share Posted February 19, 2014 Another vintage dude ! ! PM Me Rushnracin. Robbie Klima now lives in My town and I also tracked down Marty Smith, Don Lindfors, Eric Thorsen and others. I purchased Jay Wasserman's old show truck about 6 years ago. Spencer Low now lives in Colorado. Good to have You on board ! ! hi guys , well since i havent fixed all of my pictures yet i thought i would throw this old one up for ya ! 1 Quote Link to comment
denmarkboy Posted February 19, 2014 Author Report Share Posted February 19, 2014 Haven't seen or heard NAMTO referred to in many years. Used to be a member in that time period. National association of mini truck owners. Also hooker headers used to sell the engine swap kit used here. I still have new glass fire wall and trans mount for this install. Some same parts used with 3.8 Buick and TH350 also used by Low Mfg thats awesome , and correct this truck does have the complete hooker kit. i have a hooker part tag on the tunnel i will throw a picture Quote Link to comment
denmarkboy Posted February 19, 2014 Author Report Share Posted February 19, 2014 Personally I really like these rims. i think if you go with the right size, it would look great! thats my favorite to, i actually have some really close to that style already. they are boyd wheels, i need to put a couple on and see if i like em. here is what they look like on my custom 500 2 Quote Link to comment
denmarkboy Posted February 19, 2014 Author Report Share Posted February 19, 2014 so ive got the engine & trans cleaned painted, i rerouted all the brakelines down under the engine , i built my own wiring harness and now i am building custom inner fenders.. 2 Quote Link to comment
Spoona_Jay21 Posted February 20, 2014 Report Share Posted February 20, 2014 great progress man! as I have previously said. i hate V8 swaps in most mini's, but for some reason i love this one. if you ever have to sell it for ANY reason... hit me up! lol 1 Quote Link to comment
Farmer Joe Posted February 20, 2014 Report Share Posted February 20, 2014 so thats what mine would like with a GEN 1 block in it... :lol: what kind of inner fenders are you gonna make? Quote Link to comment
denmarkboy Posted February 20, 2014 Author Report Share Posted February 20, 2014 great progress man! as I have previously said. i hate V8 swaps in most mini's, but for some reason i love this one. if you ever have to sell it for ANY reason... hit me up! lol wait till you see it at canby ! i am crappy when it comes to taking pictures. i just stand back and shot, there are alot of little details i am missing ...oh yeah and its stupid ass fast too....when i get it back to a driving state i want to shot i video . just so people can see how radical this thing is.. last year i had to sell it cheap, got it back and wont be sellin it again ..sorry 1 Quote Link to comment
denmarkboy Posted February 20, 2014 Author Report Share Posted February 20, 2014 so thats what mine would like with a GEN 1 block in it... :lol: what kind of inner fenders are you gonna make? really close, i am having a craving a wagon with a v8 . actually i am looking for a cheap dd right now ...i might have found a 521 as for the inner fenders , cab back , and bed cover ....i'm keepin this to myself ...canby surprise ! i will give you a peek ! 1 Quote Link to comment
denmarkboy Posted February 25, 2014 Author Report Share Posted February 25, 2014 So a quick update , I put the engine & trans back in and apparently I did not set the converter on the pump correctly. Results, I fried the trans pump, Saturday I took it all back out again . Trans is at o.t.s. should have it back this week . I am getting pretty good a pulling this combo . Did it from a runner to completely out trans and motor separated in less than 2 hours . 1 Quote Link to comment
denmarkboy Posted March 3, 2014 Author Report Share Posted March 3, 2014 lol, hes got a whole month and a week to get it done.. he said end of february, right? hahaha Ok farmer its time to say you told me so !!! Hahaha its March and the trans is still in the shop, I have started paint . But I have started sheet metal, I also threw a 521 build into the mix, I am going to try and get it into a driving project before canby. 1 Quote Link to comment
