Thomas4258 Posted April 11, 2013 Report Share Posted April 11, 2013 Clutch 7 7/8 X 1 X 24T /200mm All components are engineered to function as a precisely matched system Includes all-new pressure plate assemblies, disc assemblie, release bearing, pilot bearing/bushing, and alignment tool. Transmission 5 speed Could fit a 620 truck, first year 720 truck, 280z, 280zx or 810/Maxima. It is 31.5" long, and have a front and rear aluminum case sandwiching a 1" thick steel adapter plate between it. Clutch/Transmission SOLD Link to comment
datzenmike Posted April 12, 2013 Report Share Posted April 12, 2013 Well the rear trans mount is a z or zx not a Maxima. It does not have a top gear or a neutral switch and has only a reverse lamp switch. Only the zx non turbo and the Maxima had this. It has a reverse check sleeve which wasn't listed as being on the zx 5 speed but was on the Maxima. I'd say a mid '80 and up Maxima 5 speed possibly swapped into a z car. If not, then a zx 5 speed. Another thing is the striking rod guide. This has the lower pin holes and takes a tall shift lever where as the 280zx was known to have a short shift with a higher pin location. Place in 5th and turn the input spline 10 times. If the output turns 7 1/2 times then it's more likely a zx 5 speed. Link to comment
Thomas4258 Posted April 13, 2013 Author Report Share Posted April 13, 2013 Okay cool, thank you i was told it was what i had listed before. Link to comment
DATSUN671 Posted April 15, 2013 Report Share Posted April 15, 2013 would this fit a 1978 datsun 620 pickup Link to comment
Thomas4258 Posted April 15, 2013 Author Report Share Posted April 15, 2013 I believe the 620 5-speeds are all longtail. The trans should fit any 74-79 with no mods except changing the speedo pinion. Link to comment
