nustad Posted April 10, 2013 Report Share Posted April 10, 2013 I'm running 280zx front discs and maxima rears on my 72' 510. My 1980 280zx master cylinder is leaking and I need a rebuild kit or replacement. I'm having a hard time finding a kit or new master. Hoping someone can give me some direction or alternatives. Quote Link to comment
nustad Posted April 11, 2013 Author Report Share Posted April 11, 2013 Anyone have a part number for a 7/8" master cylinder that will fit in stock 72' 510 location and work with f/r discs? Any other tried and true options/ideas would be appreciated. Quote Link to comment
Laecaon Posted April 11, 2013 Report Share Posted April 11, 2013 Rockauto 1983 Maxima. Lots of options, appears to be 7/8th Quote Link to comment
nustad Posted April 11, 2013 Author Report Share Posted April 11, 2013 Looks like the 83 maxima has the horizontal bolt pattern. Would prefer stock vertical pattern. Quote Link to comment
Laecaon Posted April 11, 2013 Report Share Posted April 11, 2013 How about a 81 200sx? Quote Link to comment
nustad Posted April 11, 2013 Author Report Share Posted April 11, 2013 How about a 81 200sx? Looks promising. Quote Link to comment
datzenmike Posted April 11, 2013 Report Share Posted April 11, 2013 Get a 7/8 620 master and swap your rear residual valve in. For zx calipers a 15/16" master would be better. The S12 has 15/16" ...the mounting is wrong but the rebuild rubber seals might be the same. Quote Link to comment
nustad Posted April 12, 2013 Author Report Share Posted April 12, 2013 I tried to look for a 15/16 kit and no luck. Going to buy 7/8 for a 620. Thanks for the help. Might send my zx master out for an A1 cardone repair and return. Any one have any luck with a service like this? Quote Link to comment
nustad Posted April 13, 2013 Author Report Share Posted April 13, 2013 Get a 7/8 620 master and swap your rear residual valve in. For zx calipers a 15/16" master would be better. The S12 has 15/16" ...the mounting is wrong but the rebuild rubber seals might be the same.Can not find any year 620 with a 7/8" master. I did find a 7/8 for a 720. Did you mean 720? Quote Link to comment
datzenmike Posted April 13, 2013 Report Share Posted April 13, 2013 shit, I meant the '78-'79 620... they were 13/16". Quote Link to comment
nustad Posted April 13, 2013 Author Report Share Posted April 13, 2013 I returned the 13/16 thinking it was the wrong part. Ordered the 720 7/8 but it looks like the bleeders are on the wrong side. I'll try the 720 to see if there is an interference issue with the bleeders and clutch master. Does anyone know the part number for the 7/8 master ermish sells? Quote Link to comment
nustad Posted April 13, 2013 Author Report Share Posted April 13, 2013 Datzenmike, with my setup do I need to install the 280zx valve assembly? I'm referring to the assembly mounted on the shock tower of the 510 that diverts fluid. Quote Link to comment
datzenmike Posted April 13, 2013 Report Share Posted April 13, 2013 The old front and rear lines just go to the new master...?? Quote Link to comment
nustad Posted April 13, 2013 Author Report Share Posted April 13, 2013 The old front and rear lines just go to the new master...?? I'm in the process of converting my front brakes to 280zx and my rear to maxima. I currently have the original 510 proportioning valve installed. Do I need to install the 280zx proportioning valve? I've read posts and DQ article that say I do but I think I've seen posts from you which made me question this. Quote Link to comment
nustad Posted April 13, 2013 Author Report Share Posted April 13, 2013 "Proportioning valve? Most Datsuns don't have one. Front and rear bias is engineered at the factory by using smaller wheel cylinders at the back than the front or smaller calipers at the back than the front. The master cylinder is also designed to apply pressure to the fronts first ... this is why the fronts are at the back of the master. Because you have mixed and matched calipers the bias is totally out the door anyway." ~Datzenmike Quote Link to comment
nustad Posted April 13, 2013 Author Report Share Posted April 13, 2013 Hmm... The 720 master has the rear port first and the front port last Talking to myself now.... Going to try a 280z master. Will take the residual valves out of the zx and put them in the 280z. Quote Link to comment
nustad Posted April 14, 2013 Author Report Share Posted April 14, 2013 Sent my zx master off to cardone to be rebuilt. Cost should be less than 60. Going to research this more. There has got to be a good cheap alternative out there. Ermish sells a replacement 7/8 i just need to figure out what it is off of. Quote Link to comment
NaudiS4 Posted April 17, 2013 Report Share Posted April 17, 2013 Ermish 7/8" BMC is a Beck Arnley 072-2694. it does not come with the push rod assembly and you can use the stock 3/4 from the 510 but will need to replace the concave washer that sandwiches the push rod ball with one off of a car that uses the same size BMC. This part is a direct replacement for the following: 72-73 240z 74 260z 75-78 280z This info is from Ermish himself along with some Google searching. Hope it helps Quote Link to comment
nustad Posted April 18, 2013 Author Report Share Posted April 18, 2013 Ermish 7/8" BMC is a Beck Arnley 072-2694. it does not come with the push rod assembly and you can use the stock 3/4 from the 510 but will need to replace the concave washer that sandwiches the push rod ball with one off of a car that uses the same size BMC. This part is a direct replacement for the following: 72-73 240z 74 260z 75-78 280z This info is from Ermish himself along with some Google searching. Hope it helps I appreciate the info. This master is for a front disc/rear drum setup. I don't see how it would work with my front/rear disc setup unless I added an proportioning valve. Quote Link to comment
Laecaon Posted April 18, 2013 Report Share Posted April 18, 2013 Im sticking to the 200sx suggestion, unless you found reason for not using it... Quote Link to comment
nustad Posted April 18, 2013 Author Report Share Posted April 18, 2013 Im sticking to the 200sx suggestion, unless you found reason for not using it... I didn't try this one. I don't see any obvious differences from pics. I will order one and see if it works (1980 200sx). Quote Link to comment
nustad Posted April 28, 2013 Author Report Share Posted April 28, 2013 Update: I tried to send my 280zx 15/16" BMC to A1-Cardone but they no longer offer a return and rebuild service on this BMC. Bought a 1980 200sx 7/8" BMC from rockauto for ~$32 shipped. It is new, EIS brand, with reservoirs. Fits in the stock 510 location with no issues. I'm still installing rear suspension/brakes so the final test is yet to come. Will update when tested. Quote Link to comment
dscottdatsun Posted July 28, 2013 Report Share Posted July 28, 2013 Get a 7/8 620 master and swap your rear residual valve in. For zx calipers a 15/16" master would be better. The S12 has 15/16" ...the mounting is wrong but the rebuild rubber seals might be the same. Would the rebuild kit for the S12 MC work for a ZX MC? The ZX rebuild kit (46011-P6525) is NLA. I got three and would like to rebuild them, or has some one had success in getting them rebuilt. Quote Link to comment
KlassicMotion Posted July 31, 2013 Report Share Posted July 31, 2013 I know it's too late by now, but what I did with my 280zx front and rear disc setup with the use of the 15/16 master cylinder was to use the '79 280zx m.c. with the vertical mount, but I ordered an '82 280zx m.c. from the parts store for $40. I used the new/rebuilt plungers inside the bore to rebuild my old m.c. I've asked the same question about the proportioning valve; the answer I got was that it is not a p.v. but just a junction block to activate the brake light switch. Quote Link to comment
