Datsun R Fun Posted April 4, 2013 Report Share Posted April 4, 2013 is it hard to remove carrier bearing ? Quote Link to comment
kelowg Posted April 4, 2013 Report Share Posted April 4, 2013 It is if u dont have the right tools. I havent even tried, ended up have one piece driveline made. Biggest problem is the rubber surround thats no longer available Quote Link to comment
datzenmike Posted April 4, 2013 Report Share Posted April 4, 2013 Check... usually it's not the bearing but the rubber surround around it that rots away, allowing the driveshaft to flop around and vibrate. I've never heard of a confirmed bad bearing. Unfortunately the rubber isolator is hard to find so I wrapped the driveshaft in a strip of rubber conveyor belt and tightened it down. It worked so well that I never did replace it. Quote Link to comment
Datsun R Fun Posted April 4, 2013 Author Report Share Posted April 4, 2013 the bearing is still in good shape it is the rubber thing that crapped out. sounds like i need find a thick strip of rubber or leather to wrap around that thing and clamp down in the holder. hard part right now is the rubber or flexable peice of material to wrap shaft Quote Link to comment
datzenmike Posted April 4, 2013 Report Share Posted April 4, 2013 I used a piece of 3/8" conveyor belt wrapped around 7-8 times. Seems to me I held it together with a couple of hose clamps joined together until I could get the hoop clamp thing bolted down. Foam rubber may be too soft. Quote Link to comment
datsunaholic Posted April 4, 2013 Report Share Posted April 4, 2013 Old inner tube. Find a commercial tire store, they'd likely GIVE you one. Quote Link to comment
datzenmike Posted April 4, 2013 Report Share Posted April 4, 2013 Bicycle inner tubes, no trimming. 1 Quote Link to comment
metalmonkey47 Posted April 5, 2013 Report Share Posted April 5, 2013 Check... usually it's not the bearing but the rubber surround around it that rots away, allowing the driveshaft to flop around and vibrate. I've never heard of a confirmed bad bearing. There's a first time for everything. Right before my driveshaft blew up a few months back, my carrier bearing started squealing. By the time I took it off, the bearing had so much play in it I was surprised it didn't fall apart. The race was chewed up inside. The surround was actually in great shape. 1 Quote Link to comment
Datsun R Fun Posted April 5, 2013 Author Report Share Posted April 5, 2013 well if i remember talk to tire guy he might give me tube if not got a few bicycle ones so i might as well try that maybe some zip ties to hold it together long nuff to get the hoop on it, if that does not work will get hose clamps thanks for the help. i wanna drive my dato round some Quote Link to comment
datzenmike Posted April 5, 2013 Report Share Posted April 5, 2013 Make sure it's snugly tied and clamped down tight and this will work. Quote Link to comment
ghammer Posted April 5, 2013 Report Share Posted April 5, 2013 Just Had My Driveline Shortened Recently, They Asked If I Wanted My Carrier Beating Replaced? So They Are Available. Quote Link to comment
ssnapz Posted April 5, 2013 Report Share Posted April 5, 2013 My 720 carrier bearing cost me $80 at oriellys. Took me about a hour with a impact and a small hammer. Quote Link to comment
