New guy with freshly bought 320
Will_D
Hey guys, bought myself a 64' l320 and I'm looking to get this thing back in running shape. It's missing the distributor and carburetor. Since finding parts for this actual model is proving difficult, what are some options from other models that would fit without too much trouble?
Thanks,
Will
  • Replies 19
Welcome to Ratsun  B)
Your going to need a distributor no matter what, even if you were to make an electronic ignition.
You can buy a webber carb, with an adapter, I have one on mine.
If you can find a J13-15 block/transmission, you likely could convert over to that fairly easy.
Post some pics of your new truck.
If I were you I'd post in the parts wanted or surf the parts for sale classifieds here on this site.  There is probably someone with a parts car that has a carburetor and distributor for you, in fact I know there are some on this very forum.  You can get both rebuilt.  I had my carburetor rebuilt by Chicago Carburetors ($225) and I believe you can get an old distributor rebuilt by Cardone via Rockauto ($60, core required).  Once you have one you know is operational with points you can do the EI conversion if you'd like.  My preference, for whatever it's worth, is to start with stock and get it running first and then do the upgrades/mods so you can troubleshoot more easily as you go provided you can find the stock parts.
Good luck.
Thanks guys. I may go to the junkyard and try to find a holley 5200 (weber 32/36). 30 bucks for the carb and a few more for a rebuild kit and adapter sounds like the way to go. Yay or nay?
Here's some pictures of the truck. It's pretty beat up, but for what I have planned for it, I'd feel bad for starting out with a nicer truck.
Didn't find a 5200, but I did find a hitachi carb from a ford courier. I'm pretty sure it should work. And I'll be ordering a j13 distributor once I do a compression test on the engine. I hear the j13's work with the e1's and I actually find it at the parts store.
Today I drove 45 minutes out to where I'm keeping this thing for now. Carb fits, so now I just need to rig up a throttle linkage and figure out how to wire up the electric bits of the carb. Also, I caught a picture of the distributor mount. I believe it's the older style, will I still be able to use a j13 or am I on the hunt for a unicorn(old style original)?
None of my 320's ever had a stock motor, so I don't have firsthand experience, but that distributor mount looks a lot like the BMC A or B series distributor mount, from an MG or Austin Healey or Mini, etc. I know the Datsun motor in general shares some commonalities with the BMC motors, like Intake manifold. Try hunting down a distributor from an MGB, should be easier than finding the real thing.
I have a few here if you want some pics to compare.
  • 7 months later...
My thoughts exactly!  Look for a British car specialist in your area (I know there were some a few years ago), and ask to buy a $10 dirt cheap early point style 25D distributor CORE to test fit (1959-1974 MGB Midget Sprite Mini, should be a dime a dozen!).  If it fits, you can call Jeff @ Advanced Distributors, tell him what you are doing (great guy, always willing to work with odd applications), and he can set you up with a rebuilt 25D to your specs.  Tell him TJ sent ya!!
Dude, that think is rough. I like 'em like that!
