Mr.Dean_Yates Posted April 3, 2013 Report Share Posted April 3, 2013 Not sure how to do this one. Basically my truck has sputtered at half a tank and then died, so, I know its not empty, my truck doesn't take $17 to fill (I wish it did) and with a full tank it runs perfectly fine. Gets to half and sputters out. I'll post pics of the top of my tank and stuff in a bit I'm currently using my phone and under my truck haha Quote Link to comment
datzenmike Posted April 3, 2013 Report Share Posted April 3, 2013 Replace the filter in the bottom of the pump. Check to see if another owner has added an in line one and change it too. Quote Link to comment
Mr.Dean_Yates Posted April 4, 2013 Author Report Share Posted April 4, 2013 new pump new inline filter. talking to my dad, he said there is a possibility that the pick up line inside the tank could be damaged? but there is no way for me to check Quote Link to comment
wayno Posted April 4, 2013 Report Share Posted April 4, 2013 Did the tank ever get hit on the bottom? One time I bottomed out on my mustang ll tank(my friends called it a pintang), it pushed the pickup tube up so far that I would run out of gas while still showing a 1/4 tank. Quote Link to comment
Mr.Dean_Yates Posted April 4, 2013 Author Report Share Posted April 4, 2013 not that i know of...its possible, but i dont see dents or anything like that Quote Link to comment
Dawa Posted April 4, 2013 Report Share Posted April 4, 2013 definitely sounds like you need to drop the tank,for at least a look around, or to cross out what the problem ISNT. it only takes a couple hours. Quote Link to comment
datzenmike Posted April 5, 2013 Report Share Posted April 5, 2013 Unless the pick up tube broke off and is shorter or if it was bent would this happen. Can't see that. Did the tank ever get hit on the bottom? One time I bottomed out on my mustang ll tank(my friends called it a pintang), it pushed the pickup tube up so far that I would run out of gas while still showing a 1/4 tank. Wayno, on a cross country trip I had air rushing sounds every time I took the cap off to refill. Turned out to be the cap not venting and letting air IN. The tank collapsed to half thickness and ran out reading 1/4 tank WTF??? Was in Ontario and there are NO Datsuns, in fact there are no yards with cars over 15 years old in them. So I was stuck with a squashed banana for a gas tank. I ended up using compressed air to inflate the tank, insane but it worked. Yeah it drove a block and ran out of gas. Forgot to check the pick up tube, it was bent. Quote Link to comment
DatWifey Posted April 5, 2013 Report Share Posted April 5, 2013 When we bought our 521, we were driving it from central panhandle of Idaho to central WA and it would run great for a while down the freeway, and then suddenly just sputter and die. The husband finally heard the whooshing sound you described, Mike, and put it all together. Thankfully, we didn't have the tank collapse, because it would just die first. We let it sit for a little bit after one episode, before figuring out it was the cap, and it fired right up and drove a while before dying again. Quote Link to comment
datzenmike Posted April 5, 2013 Report Share Posted April 5, 2013 I thought the air was coming out! Boy was I wrong, it was sucking in... but it run fine, until it caved in. It was a 720 long box 2wd tank... big sucker, 13 Imp gallons 16 US? Pulled the sender and held hand over the hole, vice grips clamping the gas lines and my dad's neighbor's compressor. Tank swelled and popped, scaring the shit out of me. It was empty but still smelly. After several bangs and pops it resumed it's former shape leaving just a few mild creases. I put the sender in but should have checked the pickup pipe. Had to tear it all out and reach in with a long screwdriver and push it over vertical. Quote Link to comment
wayno Posted April 5, 2013 Report Share Posted April 5, 2013 I thought the air was coming out! Boy was I wrong, it was sucking in... but it run fine, until it caved in. It was a 720 long box 2wd tank... big sucker, 13 Imp gallons 16 US? Pulled the sender and held hand over the hole, vice grips clamping the gas lines and my dad's neighbor's compressor. Tank swelled and popped, scaring the shit out of me. It was empty but still smelly. After several bangs and pops it resumed it's former shape leaving just a few mild creases. I put the sender in but should have checked the pickup pipe. Had to tear it all out and reach in with a long screwdriver and push it over vertical. That was a fun day, pulling it twice, but it went faster the second time, didn't it. :lol: Quote Link to comment
datzenmike Posted April 5, 2013 Report Share Posted April 5, 2013 That it was. For one the tools were still out. Never time to do it right but always time to do it over. Quote Link to comment
