DATSUN671 Posted April 2, 2013 Report Share Posted April 2, 2013 would a nissan hardbody brake caliper fit a datsun 620 spindle? thanks for the help Quote Link to comment
Guest Rick-rat Posted April 2, 2013 Report Share Posted April 2, 2013 Read the pinned post on top of this section Quote Link to comment
heretic Posted April 2, 2013 Report Share Posted April 2, 2013 direct bolt on, no Quote Link to comment
Dawa Posted April 3, 2013 Report Share Posted April 3, 2013 but the fabricated caliper mounts, isuzu rotors & z32 calipers and slap those on your rig Quote Link to comment
Z-train Posted April 3, 2013 Report Share Posted April 3, 2013 14 inch rims will no longer fit. Quote Link to comment
Dawa Posted April 3, 2013 Report Share Posted April 3, 2013 oh contrare (sp?) z train! we just had a member fit z calipers on 14" wheels BUT it is very dependent on the design of the wheel. Quote Link to comment
620Aaron Posted May 30, 2013 Report Share Posted May 30, 2013 If it's a disc brake, ball joint truck do you really need HB spindles? or can you just swap rotors and calipers? Quote Link to comment
Dawa Posted May 30, 2013 Report Share Posted May 30, 2013 correct, you wont need the spindles if it is already a disc brake ball joint truck Quote Link to comment
]2eDeYe Posted May 30, 2013 Report Share Posted May 30, 2013 False. You will need the hardbody spindles. The mount for the caliper is a completely different design. The hardbody spindles will bolt right up to the balljoints on the 620. Edit:Hardbody drop spindle on 620 balljoints. The hub has been turned to fit the titans. Quote Link to comment
Dawa Posted May 30, 2013 Report Share Posted May 30, 2013 oh ok i see my error. i knew that the spindles were swappable, but didnt know about the caliper mounting >< Quote Link to comment
jvb5577 Posted June 6, 2013 Report Share Posted June 6, 2013 I just ran into this problem with the caliper swap. The 620 spindles have no recess where you mount the caliper to the spindle. While the hardbody spindles the mounting is recessed to fit the larger rotor and caliper. I wish a grabbed a picture of this. I am going with the hardbody spindles off a '92. Brake calipers off a pathfinder (two piston) also a '92. Then buying new V6 hardbody rotors. Quote Link to comment
Pedro Posted June 14, 2013 Report Share Posted June 14, 2013 Anyone know if these spindles have a change of fitting a 410/411? Quote Link to comment
heretic Posted June 14, 2013 Report Share Posted June 14, 2013 admittaningly I know VERY LITTLE about 410/411's ... but with that .... I highly doubt it assuming it utilizes a strut style front suspension like the 510. Quote Link to comment
