Icehouse
How to wire a KA, CA, SR, and VG into anything
Jeff, do you have any pics of where and how you installed the ECU. Where did you mount it? I think i remember it on the floor under the seat at canby last year. Anybody else with a 510 have any pics of their ECU mounting locations?
I am looking to install in a 620, but all suggestions help.
Does a Nissan Ecu have to be mounted any way special? I assume that out of the engine bay is a must.
Jason
Share this post
Link to post
I was gonna mount mine under the dash pocket compartment, if yours is equipped with one.
Share this post
Link to post
Jason
I thought you were done with the KA idea...or are you thinking for the VG?
Under the seat, behind the seat, or under the dash. You could put it under the hood if it was in a box of some kind to protect it.
They don't really care how they're positioned, they come stock in both horizontal and vertical configurations. I would only assume that they don't like to be loose
Share this post
Link to post
That's where mine is, with the shelf in there you almost can't see it.
Share this post
Link to post
I am done with the KA idea, this would be for a VG. I originally intended to put the ECM under the glove box, aove the package tray, but i have now found the complete underdash AC system and it takes up every last bit of space under the dash. Absolutely no room under the dash for a ECM. And i plan to run and automatic, so i have to run a separate trans ECM also. Basically almost twice the space. I guess that under the seat is really my only choice now.
Jason
Share this post
Link to post
put it in the glovebox. If you still need that storage space, build a box under the seat, it'd be safer than the glovebox anyway
Share this post
Link to post
shorten the depth of the glove box and mount the ecu behind it
Jason
Share this post
Link to post
I have considered the glovebox idea. I dont really use it anyways. As long as i could get my insurance card and registration papers in there i would be happy.
Jason
Share this post
Link to post
I need help.
The orange wire from the harness to the starter solenoid confuses me.
i have a 1992 ka24de going into a 1968 1600 roadster. I have all the other wires / relays hooked up but I am hesitant about the orange wire for some reason.
I am supposed to run a wire from the hot on the solenoid to the orange on the dash connector?
Thanks in advance.
~Robert
Share this post
Link to post
Jason
Here is a shot of how someone mounted the ecu under the dash in a 510. If you flipped the ECU over, it would tuck up tighter.
318310522_681ad1c5ed.jpg?v=0
Share this post
Link to post
I just put the ECU under the passenger seat, I've though about under the dash but the wiring harness is so long I didn't want a ball-o-wires under the dash. I also thought shortening them would be way to much work, even though I did splice every wire on my dual cam CA because when they pulled the engine in Japan they used a sawzal on the harness :( Now that is not something I would want to do again.
Share this post
Link to post
I need help.
Thanks in advance.
~Robert
The orange wire on the dash connector goes to IGN. Doesn't have anything to with the started selenoid.
I usually use the vehicle's harness to wire up the starter and alternator.
Share this post
Link to post
What size wire gauge are you guys using? Should I use 8 gauge for the power from the battery to the box and then 10 gauge to the relays?
Also, relays are for what type voltage? I am going to use Bosch style 30/40A is this good.
Sorry for the questions but there seems to be so many choices for what to use.
Share this post
Link to post
14 gauge should be good enough.
Bosh 30/40A are ok. I usually go to the junkyard and get the Nissan OEM style that fit nicely in my pocket ;)
Share this post
Link to post
Pathfinders have a relay on the passenger inner fender below the hood hinge. The base that the relay plugs into has smallish gauge trigger wires but the output are really heavy wires. I have several and look really nice when wired up, very neat and tidy with no bare spade connectors showing.
Share this post
Link to post
When I wire the fuse box I use these fuses boxes and what ever relays I can find with the handy tabs, makes them easy to mount.
like this when its installed (pic in a dime passenger foot well)
The fuse boxes contain 6 fuses so if you are going to run other stuff besides the ECU and fuel pump thicker wire isn't a bad idea. Remember Tesla vs. Edison? DC current looses its gumption over short distances.
Share this post
Link to post
Thanks guys. I think that clears some things up. I have more questions but I will reserve them until I do this next week and see how it all pans out. Thanks again.
Share this post
Link to post
Here are pictures of the relays I got...
relay
relay_back
Mine seem to have five connections in the back.
On the front it has a diagram to what each point goes to.
My Question is how does the first picture of the relay diagram relate to the diagram you guys have of the wiring.
For example: point 86 would go to power cable, point 87a would go to fuse box... etc.
Get what what I'm saying? It's confusing because I don't know how these things work so I don't know how to read it. Thanks guys!
Share this post
Link to post
relay
relay_back
Thats a "Hi,Low" relay for headlights. I could work but not optimal. You need standard relays unless you want an extra pin for no reason.
30 comes from the fuse box then is switch from 87a to 87 in your case. 85 is the ground for the switching coil and 86 is the power. Hopefully that clears some stuff up for you.
Share this post
Link to post
I always ground 85.
Share this post
Link to post
Well after everything is said and done I made my own wiring diagram. Improved from the nice one already made with a more clear understanding of the relay. Also it's in PDF format for a nice clear picture. Again thanks for all the help guys. This is going into a 280Z just in case you were wondering...:eek:
wiring_for_sr20
Share this post
Link to post
