Electronic Temperature Gauge
fragginfags
  • Replies 1
It will be somewhere on the thermostat housing below the top rad hose. Z cars sometimes have 4 or more 'senders' for various functions. Usually the wire colors are Yellow/White stripe. If you find the wire clean it and ground to the housing with the key on... the gauge should read full HOT if working. If nothing then the gauge is the problem.
