Kirden
B210 Goodness: Finally Picked up a Car(Dos?)
Yay B210 goodness :)
Was told it has a JDM A15, will keep looking it over and ask a lot of questions :P
Edit: Wanted to show the new addition here as well. Shows up on the 8th page I believe:
  • Like 5
Share this post
Link to post
Bout time.......
.. lol, now ad it to your "cars" list yo!
Share this post
Link to post
Oh, and pull the valve cover and tell us the head numbers, wich dizzy does it have?
Share this post
Link to post
Nice 4 door! Jealous of the stick shift :.(
Share this post
Link to post
I took these pics right before heading to work. I will see what information I can get on it tomorrow. I was looking for the cast marking "A15" but I could not find it. Then again I have no idea where to look :P
Share this post
Link to post
Alright, more pictures :)
Valve cover off :)
Share this post
Link to post
Here is some info I found on the head. Love the 1200 site :)
H89
Oval-port Closed-Chamber was fitted to A14-powered B310 Coupe and Sedan in the JDM market (but not to Van (wagon). C120 came with A15 engine and H89 head. Closed-chamber is a non-emissions controlled head (no EGR). It is sometimes called "High Compression", but the compression is about the same as the open chamber (H72) head -- the compression is controlled by the piston dish, not the head.
  • Closed Chamber
  • Oval Port
  • Intake Water Ports
  • New intake bolt pattern
Share this post
Link to post
Yep thats a good head, ditch those manis tho lol
Share this post
Link to post
I have seen some dellorto(?) carbs that look interesting. Honestly I don't want to throw a ton of money into this engine until I figure out how it runs. There are 4-5 vacuum lines that were completely disconnected with no nearby connections. Probably countless more that have cracks ect, so buying 10-15 feet of hoses will probably be the first step.
Share this post
Link to post
Do you have emissions?
Share this post
Link to post
Yea, and it looks like I have the A14 hitachi. Back at work so I can't get any more number until tomorrow. I would like to de-smog it but first I just need to get it running. We don't have smog laws where I live (yet).
Share this post
Link to post
  I thing Banner was referring to  Do you have emission testing where you are located.    If not dont bother with the hose.  Vacuum advance is all that is required to run that motor.
Nice Score on the Car  BTW!
Share this post
Link to post
Yea, I was thinking of tryin to do away with all the smog stuff, but the hitachi has so many lines going to it.
I guess I will look into de-smogging the engine. My truck was pretty much completely de-smogged when I got it, so I don't know what I can/can't remove. Time to use the search button :P
Share this post
Link to post
Yea, I should be able to check tomorrow.
Share this post
Link to post
Before you remove all the smog stuff can you do me a favor and see if your B210 still have the following hose conected and if so where does it go to.
http://community.ratsun.net/topic/53370-emission-hose-mystery/?do=findComment&comment=877556
Thanks in advance.
I posted a pic of what I have in your thread. It is not exactly the same but hopefully it will help. I think I have a different manifold than you do.
Alright, we looked over the engine and figured out where all the hoses are supposed to be connected except for one. It comes from the fuel pump and has been plugged. Here is the pic:
Looks like I have to work Friday so I only have Sat-Sun to work on it. My gas tank is full of sand/crystals and I have no gas cap, pretty sure all of the hoses need to be replaced. Masters are bone dry so that is another lovely part of the project. If I can get the fuel system and brakes done this weekend I'll be happy.
Share this post
Link to post
It was raining off and on today so I didn't get much done. Got the tank out:
Sending unit out, its pretty trashed:
There is a thin layer of gunk/rust in the tank. Calling a radiator shop tomorrow to see about hot tanking it with the radiator, if that doesn't work out in will ride in the back of my truck with a few fist fulls of rocks.
Also want to find someone with a media blaster to tank care of this:
Also removed the back seat, no pics though. Back seat frame is in good shape, finally have a frame to try my hand at upholstery. Will be looking for some interior pieces but it will be slow. Found out I have to pay out about $3k by the end of the year... Gotta love those student loans.
Share this post
Link to post
Rain rain go away...
Alright, so I love the way this B210 looks except for the mirrors. Anyone know what lip this is?
I want these mirrors and grill:
Also, kinda like the wheel styles on these cars. Similar but different number of spokes. Hard to decide between these and snowflakes.
Share this post
Link to post
I am still looking for information on this plugged hose from the fuel pump. It is not the one from the tank nor the one to the carb, as those are hooked up. Is this line needed? I am trying to button up the small things to lower the possibilities once we try to get it running. I do not have a service book yet, it is on order from vatozone.
Share this post
Link to post
a fuel pump only needs an IN and an OUT,  so keep it plugged.  or better yet, buy a new one from rock auto.
Share this post
Link to post
Thank you. I have been looking for information on this but every search I have done comes back with vacuum line diagrams. I will most likely get another since I need a filter, all new feul lines, and a new sending unit. I just wasn't sure if the replacement comes with three hook-ups or just the two.
Share this post
Link to post
ive honestly never seen an A series motor fuel pump with more then two.  maybe it was for a dual carb set up?  i dont know. but i can say that you have no need for it.
Share this post
Link to post
Thanks for the input king bee. I should get around to working on this this weekend, since it is supposed to be a wonderful 75F weekend. I ordered a hitachi rebuild kit, fuel pump, and oil filter from rock auto. Had the get the most expensive oil filter cause it was the only one besides Fram from the same warehouse, not that $5 is really all that bad.
The fuel tank is cleaned and coated, ready to be reinstalled. Going to pick up new fuel and vacuum hoses and clamps all around. I have an extra fuel filter from when I installed the weber on my truck, accidently ordered two. Still need to get plugs, valve cover gasket, oil pan gasket (going to drop the pan), air filter, and a wingnut for the air cleaner.
Is the hose that comes from the exhaust to the front of the intake needed? Mine was cut off by the PO and my truck doesn't have it either, but my truck never had the stock carb. The hose I am asking about comes from the exhaust manifold. It is silver and looks like a dryer exhaust hose for a house.
Reference shopping list for this weekend:
Valve cover gasket
Oil pan gasket
Spark plugs
Air filter
Fuel and vacuum hoses
Wing nut for air cleaner (anyone know the thread?)
Fuel cap
Radiator cap
Oil (best weight?)
Carb cleaner
Also, how hard will it be to remove the oil pan while the engine is in the car? Not sure how much room is under there for removal.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
